spudering engine sound, firebird 2001
More recently the engine has been making a spudering sound when the gas is pressed. The more it is pressed the louder it gets. It seems to have less power and I can only assume it could be a blown head gasket, a miss-firing spark plug, or maybe a lifter. But based on how I described it is their anyway to figure this out without going to a mechanic to rip it all apart?
I assume you have NO SES light or codes in the PCM....? You should go get a code scan even if you see no SES light on.
I personally think you have a failing 02 sensor(s)........your symptoms are exactly that.
Does the hesitation clear up if you hit the pedal down harder and try to accelerate...?
P0420 - Catalyst System Efficiency Below Threshold Bank 1
P0128
P0128 - Coolant Thermostat Malfunction
Yes the ses light is on and has always been on since I got the car pretty much, abs and low oil light, but i think the low oil light is going on because the gauge isnt working and not moving, but plenty of oil.
P0420
P0128
P0128
Could just need a new coolant temp sensor....
Is your temp gauge working normally..?
