HELP. WS6 4l60e leaks fluid from vent tube
Old 09-10-2014, 02:40 PM
Gotit4cheap16's Avatar
Default HELP. WS6 4l60e leaks fluid from vent tube
So I have transmission fluid leaking from here (my trans vent tube) ....I just added a bottle and it leaked straight out at idle....how to I fix this? Or what is the cause?
Old 09-10-2014, 04:56 PM
Moderator
mrvedit's Avatar
What is the level of the ATF in the trans according to the dip stick.
If it really is leaking out of the vent tube (you are sure?) the trans is either overfilled or overheated. I had it happen when one of my "hydraulic mod experiments" caused the TCC to drag and burn up.
Old 09-10-2014, 05:44 PM
Yes I got under the car and had the car on idle after pouring a bottle of fluid in and it poured out
Old 09-10-2014, 07:12 PM
BubaGumpShrimp's Avatar
dumb question, why did you put a bottle of fluid in?
Old 09-10-2014, 08:15 PM
Because I was getting delayed and weird shifts and I checked the fluid and it was low.
Old 09-21-2014, 12:02 PM
libertyforall1776's Avatar
There have been some other posts here on this topic, most likely from heat, and the fix may require some extra vertical tubing to help prevent this. Obviously you do not want trans fluid dripping anywhere near headers due to fire risk!
Quick Reply: HELP. WS6 4l60e leaks fluid from vent tube
