HELP. WS6 4l60e leaks fluid from vent tube
Moderator
What is the level of the ATF in the trans according to the dip stick.
If it really is leaking out of the vent tube (you are sure?) the trans is either overfilled or overheated. I had it happen when one of my "hydraulic mod experiments" caused the TCC to drag and burn up.
