335 or 345...what size rim is needed?????
Originally Posted by gator's 99TA
you wont hook any better. it must be just for looks then.
Originally Posted by cantdrv65
All tires are a joke when you make 500rwhp and up
850 on the dual shot
Progressive controller, here I come.
I have 335/30/18 pilot sports on my 10.5" OE Z06 rims no problems at all. Also looks damn good.
Here are a few pics of 335s BFG R1s on my "too narrow" rims {17X10.5s}.
The minimum recommended wheel width was something like 12 inches. The tires didn't work worth a hoot on the narrow rims. They would stick great then just let go all of a sudden. Not very controllable at all. The only time I've even spun out on accident was when I was running these tires. They also didn't work good at all at the strip {no suprise there}.
335s and 345s have to weigh a TON! I used to have AFS chrome ZR1s with 17x9.5/17x11s with 275/315 BFG Comp T/A ZRs (not drag radials) and the 315s were obscenely heavy; had to be almost double the weight of the stock silver 17x9s w/ 275-40zr-17 F1s. I definetly could feel the difference with the added weight in acceleration over the OEM set-up. With that much power...you ought to just run Mickey Thompson ET STREETS. I ran my 26x10.5x16 ET STREETS for a few weeks on the street and traction was NEVER an issue; even with 30ish psi. If I had your power I wouldn't waste my time with plain street tires.
