335 or 345...what size rim is needed?????
Old 05-23-2004, 11:54 PM
Quickin's Avatar
Default 335 or 345...what size rim is needed?????
Thanks.
Old 05-24-2004, 12:01 AM
Judd's Avatar
Kumho has a 335 with a minimum wheel width of 11 inches, most other 335s require a 12 inch rim. Check out TireRac for absolute specs though, I could be mistaken.
Old 05-24-2004, 12:14 AM
ReaperSS's Avatar
11.5 to 12 inch would be my suggestion
Old 05-24-2004, 03:30 AM
alexWS6's Avatar
11.5" minimum for 335
12" minimum for 345
Old 05-25-2004, 10:34 AM
cantdrv65's Avatar
Thumbs up
I have 335/30/18 pilot sports on my 10.5" OE Z06 rims no problems at all. Also looks damn good.
Old 05-25-2004, 12:07 PM
gator's 99TA's Avatar
you wont hook any better. it must be just for looks then.
Old 05-25-2004, 12:39 PM
cantdrv65's Avatar
Smile
Actually they hook quite well for a street tire....No bulge in the middle so I cant see why they wouldnt hook just as good or better than a 295....
Old 05-25-2004, 12:51 PM
because this cat makes about 500 rwhp - so those tires are a joke.
Old 05-25-2004, 07:13 PM
cantdrv65's Avatar
All tires are a joke when you make 500rwhp and up
Old 05-25-2004, 08:08 PM
Quickin's Avatar
It'll be close to 700 RWHP on my 150 shot
850 on the dual shot
Progressive controller, here I come.
Old 05-26-2004, 05:24 PM
LS69TA's Avatar
How did you get yours to seat on the rim? We had over 100 psi and the bead still wouldn't seat on my 10.5 Z06 rims. I still have the brand new tires sitting in the garage. Sold the wheels with the car because I figured I'd have to get some 18x12 Fikse's ordered.
Old 05-28-2004, 05:27 PM
Rookie Hawker's Avatar
LET'S SEE SOME PICs!!! This sounds very very sweeeeet!
Old 05-29-2004, 12:22 AM
Judd's Avatar
Here are a few pics of 335s BFG R1s on my "too narrow" rims {17X10.5s}.
The minimum recommended wheel width was something like 12 inches. The tires didn't work worth a hoot on the narrow rims. They would stick great then just let go all of a sudden. Not very controllable at all. The only time I've even spun out on accident was when I was running these tires. They also didn't work good at all at the strip {no suprise there}.
Old 05-29-2004, 12:39 AM
14u2nv's Avatar
335s and 345s have to weigh a TON! I used to have AFS chrome ZR1s with 17x9.5/17x11s with 275/315 BFG Comp T/A ZRs (not drag radials) and the 315s were obscenely heavy; had to be almost double the weight of the stock silver 17x9s w/ 275-40zr-17 F1s. I definetly could feel the difference with the added weight in acceleration over the OEM set-up. With that much power...you ought to just run Mickey Thompson ET STREETS. I ran my 26x10.5x16 ET STREETS for a few weeks on the street and traction was NEVER an issue; even with 30ish psi. If I had your power I wouldn't waste my time with plain street tires.
Quick Reply: 335 or 345...what size rim is needed?????
