sale/trade umi m6 torque arm relocation bracket
Category: Steering & Suspension
Price: $200
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NE
Item Condition: Used
LS Engine?: Fits LS Engine
The torque arm relocation kit from UMI Performance is designed to remove the front mounting point of the torque arm off the transmission and protect the tail shaft from damage. General Motors tail shaft mounted design works great for a stock driven vehicle however it is not designed to take abuse and hard launches. This set-up replaces your transmission cross member with a new stronger set-up with a built in torque arm mount. Each relocation kit is designed to fit a specific transmission and will work with virtually any stock style aftermarket torque arm as well as the factory torque arm. This unit is built using rectangular mild steel tubing, 0.188” mild steel mounting plates and includes all appropriate hardware needed for the installation. The torque arm mount is machined from 0.250” thick mild steel and features a new clam shell for appropriately attaching the torque arm to the new cross member. Please use the FAQ’s below for additional information.
dumWhat does this kit do?dum
dumOur transmission cross member is supplied with a built in torque arm mount removing the torque arm from the transmission tail shaft and protecting it from failure.
dumDoes this new relocation kit reduce ground clearance?dum
dumNo, our cross member is designed to tuck tight against the vehicle chassis and will not effect vehicle ground clearance.
dumWhich brand torque arms will this work with?dum
dumThis set-up will work with virtually any torque arm on the market as long as it bolts into the stock location. It will also work excellent with the stock torque arm.
dumDoes this add additional weight to my vehicle?dum
dumNo, this cross member in most cases will save weight over the stock unit while being structurally stronger.
dumDoes this kit require any drilling or welding?dum
dumThis kit is 100% bolt in and requires no drilling, no cutting and no welding. It bolts in place of the stock cross member using the existing holes.
dumThis product must be used with a solid one-piece polyurethane bushing. It will not work with the factory bushing that utilizes a two-piece design. If using a stock torque arm with this relocation kit an aftermarket polyurethane bushing must be purchased. This item can be purchased below, Item # 3004.* Item # 2214
dum
dum
