4kHP A/W intercooler, Manifolds, Morel Lifter, burkhart man. rack, BMR SFC, RHS head
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Factory 2002 WS6 exhaust. Around 30k miles on it. It was cut to make for easy install,removal. The band clamp is included. $200 LOCAL ONLY.
Stock front sway bar from a 99 T/A. $20 LOCAL ONLY
MSD wires, very low millage. 200. Only reason I am selling is my new setup has the coils relocated and the wires need to be longer. $40.
Ls1 lifter trays. Also only have about 200 miles on them. Price is for all 4. $20
Morel solid roller lifters #4737. Set of 14. You would need to buy 2 more(part #5911) $100.
Track Manifolds. Comes with heat shield. $80
BMR Boxed subframe Connectors, Weld-on, Non-convertible Only. Black in color. $50 local
*NEW* Burthart manual rack adp. $100 FIRM
This lets you bolt up a manual rack to a k-member setup for a stock style rack.
RHS Pro Elite part # 54210 LS1 head. Brand new in the box. This is only ONE head, not a pair. These were the ones manufactured by EPT not the newer RHS that are made by Dart. Here is a link to the specs: http://c452191.r91.cf2.rackcdn.com/i...ge/54210is.pdf
I was going to try and find a second one, but ended up going to a bigger bore motor and using different heads. If you can find a second one, you would be able to score a set of awesome heads sick cheap.
$350 Shipped.
Rear Ls1 cover. Part# 12598301 . Bottom of it was ground to work with a ERL main girdle. $25
Ls7 BILLET OIL PRESSURE ADAPTER -12AN O-RING FITTING $40
