Fluid change issue/rattle noise
Okay I had a lil trouble labeling this topic....I have an 02 trans am ws6 with a 4l60e trans I have just completed changing the fluid in it as well as changing the filter. After I was done I let it idle and warm up and than cycled each through the gears at idle each for a few mins and than took it for a test drive everything was fine. Later in the evening I took it out for a longer ride as I was waiting in a drive thru I heard a faint metallic clunking/rattling/banging like my exhaust was hitting something but its only really audible in the car in park and neutral. Does anyone know what this might be ?
Moderator
You might want to use a mechanics stethoscope ($10?) to try and locate the source.
Any chance something is loose inside the trans pan? Like the brass filter seal?
