Need of some Intake advice on my new 408 build
Old 11-15-2014, 08:23 AM
bad65nova's Avatar
Default Need of some Intake advice on my new 408 build
I am trying to figure out what kind of intake and throttle body I should go with. I am build a LS swap mustang and putting in a 408 with RHS CNC'd heads. Should I go with a Fast 102 and throttle body, or a super victor EFI with a Accufab 4150 throttle body, or the Super Victor EFI with a elbow and a throttle body. This car is going to be a street car only. So what does everybody think.
Old 11-15-2014, 08:49 AM
Tuskyz28's Avatar
Cathedral heads or rectangle port heads? You said street car only...... I honestly do the fast. It would have better drivability and more torque under 6500rpm where most real street cars live life. I wouldn't do a hi rise setup unless you plan on spinning the car up to 7 plus rpm down the quarter all the time. A ported fast would be the hot ticket in my opinion...
Old 11-15-2014, 08:56 AM
bad65nova's Avatar
Sorry Cathedral heads, I also am planning on putting a Turbo on this summer
Old 11-15-2014, 08:59 AM
Tuskyz28's Avatar
No problem.... I don't know nothing about turbo builds.. I thought you was talking all motor here. Maybe somebody that knows turbo builds will chime in and help you out. Good luck bro!!
Old 11-15-2014, 10:14 AM
bad65nova's Avatar
It will be all motor for awhile
Old 11-16-2014, 09:27 AM
Tuskyz28's Avatar
I'm go bump the thread for you !! Someone that know turbos chime in please!!
Old 11-16-2014, 09:56 AM
ws6turbo's Avatar
Lsx R 102 here, couldn't be happier, the Vic Jr. Is way bigger and uglier to begin, the fast makes power under 6000 , it makes good power all across the board where the Vic only makes good power at certain rpm,
People run both no problem, but the fast is definitely a better product especially if your using as a DD , the fast will be nice for that since it makes good power at all rpm, I'm not positive on the Vic but I think it's peak power is around 6k,so ask yourself this, how often are you going to be at 6k rpm on the street like you would a track., not very often for me or I would be ripping through traffic like a mad man.
Old 11-16-2014, 10:02 AM
ws6turbo's Avatar
X2,,, street cars generally live life under 6k, which is where the fast performs well and the Vic does not do so well.. turbo or nit I say that 408 deserves a fast .. plus it'll still look like a ls when you open the hood. . Only thing I would have changed is got the black rails. Since I'm doing my under hood black.
Old 11-16-2014, 08:34 PM
Realcanuk's Avatar
I would use a stock LS2 manifold if you are adding boost. They are good to 1000 hp plus and don't break under boost.
Old 11-18-2014, 04:18 PM
bad65nova's Avatar
The Fast it is. thank you everybody
Old 11-18-2014, 07:09 PM
ws6turbo's Avatar
Good choice, you will either need the fast rails or ls2 rails.. if your getting fast rails you can get black or red. . Wish I would have got black, the red isn't the same red as the X on the manifold, and it not quite dark as the red fuel fittings from aeromotive
Quick Reply: Need of some Intake advice on my new 408 build
