tranny cooler and braided hose kit?
Old 12-10-2014, 03:19 PM
Bobs-00-SS's Avatar
Default tranny cooler and braided hose kit?
Does anyone offer a kit that comes with both? I am in the middle of completing my 4l60 swap and need to get parts ordered. Thanks!
Old 12-11-2014, 08:25 AM
01ssreda4's Avatar
This may help https://ls1tech.com/forums/automatic...oler-line.html
Old 12-12-2014, 05:51 AM
forcd ind's Avatar
I prefer the teflon high pressure hose-sometimes I get a length of it, and the ends and make my own-I have been going to a hyd supply store lately and just having them make them up
I see kits with rubber hose, but I shy away from those hoses
Old 12-12-2014, 09:25 AM
Moderator
mrvedit's Avatar
I agree on the Teflon hoses; for one thing they have a smaller external diameter than regular braided hoses.
Since factory hard lines are 5/16", AN-6 with a 3/8" internal diameter is plenty big.
Here is a similar recent thread:
https://ls1tech.com/forums/automatic...ns-cooler.html
Old 12-26-2014, 05:28 PM
SMEC-SS's Avatar
I just did a B@M race cooler with braided line. Have about $230 in fittings and line
Old 12-26-2014, 07:08 PM
Moderator
mrvedit's Avatar
That seems high for just fittings and line.
10ft of AN6 teflon hose is $20
4x Teflon fittings is $90
AN6 to trans adapters is $20
2x AN6 male-to-male fittings is $12
Total of $142.
Correction (now that I have time to research everything)
15ft of AN6 teflon hose is $75
4x Teflon fittings is $80
2x AN6 male-to-male fittings is $6
Total of $181.
Total of $
Last edited by mrvedit; 12-27-2014 at 09:08 PM. Reason: Correction on length and price.
Old 12-27-2014, 10:44 AM
01ssreda4's Avatar
10 ft aint gonna get you to the front of the car and back! I used 20 and had a couple of feet to spare.
Old 12-27-2014, 12:55 PM
Jake's Performance's Avatar
10 feet will easily get to the front of the car and back to the transmission.
Usually takes one piece slightly longer than the other. I usually have more than a foot left over.
We've done this install in the shop dozens of times and sell a cooler, hose, and fitting kit.
I would like to know where anybody can get braided or teflon hose for $2/ft.
Old 12-27-2014, 05:02 PM
JRENIGAR's Avatar
Price of said kit and will it be enough hose to work on a late model 4l80e with the return line farther to the rear?
Old 12-27-2014, 05:21 PM
01ssreda4's Avatar
I have an fbody sitting in my garage, I have a thread that clearly shows I know how to make AN line. 10 feet of line isnt enough, especially when you have to route around headers and get up to the front of the AC condenser etc. However, if its up for debate, I will be happy to go get a tape measure, walk outside, and PROVE you wrong.... if you like!
Here's my cooler, mounted behind the bumper (previously on the condenser) and there is "maybe" 3 feet of extra from a 20ft piece of hose, split evenly for the two runs. Its about a foot in front of the condenser but sightly lower also.
Old 12-27-2014, 05:27 PM
Go get your tape measure.
I have also sold dozens of the kits with 10' of braided line and all my customers have been able to successfully do it.
We run the lines from the transmission along the oil pan rail, to the condensor area, like the stock lines.
Just had a customer pick their TA up on Friday that we did the complete 4L80E install.
Old 12-27-2014, 05:33 PM
It's $250. Myself, my customers, and my techs have all be able to successfully do it, but as you can see in this thread, some individuals are challenged and can barely do it with twice as much hose.
Old 12-27-2014, 07:40 PM
01ssreda4's Avatar
Curiosity go the best of me. Tape measure from approx middle of the pan, 5 foot gets you to approx the middle of the headlight. That's no up and down, no left and right, no routing whatsoever. If it fits with 10 ft, damn it must be a tight run, I'd like more freedom to route away from heat, belts, or anything else I see fit. 10ft would not work for me, or my car, ever. I'd rather have a few feet extra, then be one inch short. But then again, that kinda stuff shows in everything you do in life
Old 12-27-2014, 09:03 PM
Moderator
mrvedit's Avatar
10 feet will easily get to the front of the car and back to the transmission....
Sorry, it is $5/ft and I suspect I used more than 10ft too. I updated my thread above.
(I spent the holidays out of town and didn't have quick access to all my info, nor my car. Sorry)
Old 12-27-2014, 09:04 PM
It's pretty simple really. I do it for a living, every day.
It shouldn't take 2 times the wheelbase of the car to run from the transmission to the front of the condenser, and it doesn't.
I very often make stock type steel lines from hard tubing. 2 60" pieces gets the job done.
As I stated earlier I generally have about a foot left of a 10' piece to run lines on a 4th Gen F body and I've done it in my shop at least a couple of dozen times over the last 5-6 years. Not counting all the older muscle cars, pickups, and other types of cars we've done.
I've sold probably 80-100 of the cooler, line, fitting kits over the last few years as well. Nobody has had issues installing them.
Obviously there are exceptions for certain vehicles, coolers, routing, etc but I know what works for us and our customers.
Old 12-27-2014, 10:02 PM
(SS)'s Avatar
When i did mine i bought 20' of steel braided line and fittings from summit as suggested from another post.I cut it in half and 2-10' runs fit perfect and i mounted mine in front radiator.
Old 01-02-2015, 05:00 AM
suicidal racing's Avatar
15ft of black fragola hose $65
4l60e -6 trans fittings $18 shipped ebay
2 -6 45°s,2 straight fittings $25 shipped ebay
20k gvw cooler with male fittings on it 50$ shipped ebay
Total $158
Quick Reply: tranny cooler and braided hose kit?
