Will cut bmr torque arm still fit 10 bolt?
Old 01-10-2015, 05:32 PM
sweet99ss's Avatar
Default Will cut bmr torque arm still fit 10 bolt?
Well to fit my s60 rear end I had to cut the outer bolt holes on one side of the torque arm as the instructions say. Looking to sell it now and I'm wanting to make sure it will fit 10 bolts before I list it?
Old 01-10-2015, 07:21 PM
Carl at CRP's Avatar
I don't think it will work on a 10-bolt now that the inner holes have been cut for the S60.
Carl
Old 01-10-2015, 07:34 PM
sweet99ss's Avatar
Dang it! That will limit the market a bit, but oh well. Thanks for the info Carl!
Old 01-10-2015, 07:40 PM
Fullen's Avatar
Why wouldn't it fit? I had to cut mine to fit an S60, but it should mount up just fine. Just mount it on the remaining holes.
Old 01-11-2015, 09:36 AM
01ssreda4's Avatar
No, a new bracket is about $70. 10 bolt uses the holes you cut.
Old 01-12-2015, 12:38 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
One of our BMR torque arms with a bracket that has been cut to fit a S60 will not bolt to 10 bolt due to the missing mounting holes on the bracket that were cut to make it fit the S60. You have to use the set of holes further to the passenger side of the car to locate everything properly. If you try to use the set of holes further to the driver side of the car it will bring the torque arm inward and you will have clearance issues with the torque arm mounting bracket and rear end yoke.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 01-13-2015, 09:55 AM
sweet99ss's Avatar
Will it fit the 9" rears in f-bodies or I can only sell it to someone with a s60?
Old 01-13-2015, 10:16 AM
BMR Sales2's Avatar
It will fit with any of the aftermarket rear ends so it will work with a 12 bolt, 9", or S60.
__________________
Glenn ***
Sales Tech
813.986.9302
Quick Reply: Will cut bmr torque arm still fit 10 bolt?
