11 Second Club Snake eyes are a good thing
Hit the 12's and 11's on the same night
Old 01-22-2015, 05:48 PM
Outthahole's Avatar
Default Hit the 12's and 11's on the same night
1st run I had 26lbs of air in the 305/35/18 Nitto 555R's spun bad in 1st &
2nd gear Leaving @3K Rpm's I ran 12.574 w/2.13 60ft. @118.48mph
2nd run I lowered the air to 18lbs and left @3k but it tried to hook up and it bogged and I went a 12.824 w/2.36 60ft. @117.53mph
3rd run just lined up and ran same set up as 2nd run,& a hot lap of the 2nd run. I left @3500 Rpm's and rolled out on the clutch ran 11.97 w/1.93 60ft. @120.64mph.
Old 01-22-2015, 06:03 PM
HCI2000SS's Avatar
Are the temps cold where you are at by chance?
Old 01-22-2015, 06:10 PM
scotty2000ss's Avatar
Crazy what a good 60ft can do.
Nice run!
Old 01-22-2015, 07:13 PM
Outthahole's Avatar
It was @58-60* 55% humidity 30.01ap,Not sure what the da was but it was cloudy and rain was about 2hrs way. Hows the Trutrac holding up in ur 10bolt? What do you 60ft.?
Old 01-22-2015, 07:17 PM
Outthahole's Avatar
Nice run!
Yep,need a good 60ft. I could have got more but I didnt want to chance fubr'ing the stock 10bolt. I needed to drive it back home 1 and a 1/2hrs away. Motor was heat soaked a lil bit too.
Old 01-22-2015, 08:44 PM
HCI2000SS's Avatar
Gotcha! The Trutrac may be the one thing holding stuff together at this point lol. I only got one track visit so far (with only 2 passes) and had a 2.0 60ft, so I haven't really tested the limits i'm sure. But i've done several 2nd gear blasts on these BFG dr's on the 125 shot and she is still holding up...knock on wood lol
Old 01-22-2015, 08:56 PM
oChristiano's Avatar
You have LS3 heads on a LS1..?
Old 01-22-2015, 10:16 PM
Outthahole's Avatar
No I have LS-6 heads that are ported with 2.02 valves in them. I need to fix that in my sig and clean my sig up cuz it looks pretty bad all jumbled out. I must have been drinking when I did it! Lol
Old 01-22-2015, 10:25 PM
Outthahole's Avatar
What was your et? I had a Trutrac in my 89 Silverado's 10bolt and it held up to my 505hp 383 stroker and 150 shot of Nos. Best 60ft was a 1.79 w/a 5-spd tranny. I was more worried about the stock trans then the rear. It went 12.7 motor & 11.8's spray and the rear lived just fine but I was told the truck 10bolt was stronger than the car 10bolt. I wonder how my rear would hold up with moser axels,trutrac,rear cover with carrier bearing support ect.. would hold up? Who knows,I might just try it!
Old 01-27-2015, 02:50 PM
Outthahole's Avatar
The 11 sec pass.
Roof delete
Old 01-27-2015, 04:43 PM
99peweterls1's Avatar
Was this a Wednesday night at NPR?
Old 01-27-2015, 06:54 PM
Outthahole's Avatar
Yes it was. It was last Wed night on 1/20/15. Were you there running too?
Old 01-27-2015, 07:37 PM
Cool man, no I did make it out for Wednesdaybut, I Had a couple buddies that went. I did was able to mAke it Saturday for the Pro TNT though.
Old 01-27-2015, 08:04 PM
Outthahole's Avatar
Yea they didnt prep the track at all from what I saw and could tell but I had fun. Just wanted to go out and run the 11 so I could say it's an 11 sec car instead of,well it should run 11's easy from what my builder say..Lol My builder had built basically an identical motor for another guy in a auto trans car that ran 10.9's to 11.1's so we knew what it was capable of but my car is full weight on 18's and the other guy has a lot of weight reduction on 15's. After I get slam air bags on my new F-150 I'm gonna bring it on the trailer and drop the air pressure and make some hard launches to see what it will do and play with the compression/rebound settings on the rear Viking Coilovers. They were on the street setting that CSC Customs had them on since they installed them for me. They should help let the car squat. It didnt squat much Wed night as they were set kinds stiff for the road to keep my rear wheels from hitting the fender wells on hard bumps. Hit me up next time ya go,If Im off ill meet ya out there.
Old 01-28-2015, 07:26 AM
Good deal, that's the fun part (dialing in the car). I doubt you'll have a problem doing that with your setup. I'll let you know when I head to the track again, hopefully I can get a couple other cars to come to.
Old 01-29-2015, 09:29 AM
Outthahole's Avatar
Your right it is fun,especially when you hit the sweet spot. Next time out I hope to bring it on a trailer so I can hammer on it a lil harder. I plan on softening up the compression,and slowing the rebound and drop the air pressure to @12-15lbs and see if I can hit the 11.4 mark. I may even delete my front sway bar. I see a lot of people do it but I'm not sure if its just a weight reduction or helps free up the front to help the car leave. Just hit me up next time you go to NPR. I like the blk on blk with your car! Looks badass!
Quick Reply: Hit the 12's and 11's on the same night
