(8) Siemens Deka 75lb / 87lb Fuel Injectors LS1 LS6 LSx EV1
Category: Engine - Intake/Fuel
Price: $275
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, Front wheel drive vehicles
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Used for 5k Miles.
These injectors will fit LS1 LS6 LSx as well as most Fords.
They are low impedance and may require the use of a resistor pack.
75lb @ 43.5psi
87lb @ 58psi
275 shipped
Item Code: FI11445
Weight: 95.00GM
Brands: DEKA
Manufacturers : Siemens (Continental)
Stock: Yes
Model: 3145FM
Categories: Fuel Injectors - Low Impedance
Retail P/N: 3145
Manufacturer P/N: FI11445
Static Flow lb/hr (n-Heptane): 74.7
Static Flow cc/min: 769
Static Flow Tolerance +/-%: 4%
Dynamic Flow (mg/pulse): 16.9
Dynamic Flow Tolerance +/-%: 4%
Coil Resistance Ohms: 2.35
Spray Pattern: Pencil
Connector Type: Minitimer (Bosch EV1)
O-ring Type: Viton
