Dual walbro 255s hobbs switch
ok so I decided to go with the dual walbro 255. doing a lot of research but cant find all the answers im looking for. I need the part number for the hobbs switch and where to get it from also z0238the Y fitting to merge them I also purched this from summit part number http://www.summitracing.com/parts/via-80238
is this all I need? or do I need anything else anyone have a parts list?
http://www.jegs.com/c/Fittings-Hose_...00712/10002/-1
That has a lot of AN Ys and tees, see if something fits your needs
Meth should run either off the MAP or MAF , not a Hobbs. At least my Alky Control meth works that way. Not sure of other companies.
Don't have them with me. Look on racetronix website. If I remember right it's HPS-2 (the 2 being 2 psi) HPS-7 for 7 psi, etc. the connector is seperate but listed with the switch in the site.
