Feeler sale PRC 2.5 6.0 heads, push rods and ms4 cam
Category: Accessories
Price: $1
Location (State): NY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Can you tell us a little bit about your combination and what kind of numbers it made with that cam and heads? I'd be interested in both. Did you have to fly cut the pistons to get the cam to fit or was it a stock short block?
Scott
Scott
2002 ss camaro m6 with a stock bottom end ls2 swap . These heads and cam . Out of the box 102/102 , FTP 98mm lid and 85mm maf . Texas speed 1 7/8 long tubes , bassani true dual cat back , racetronix pump and ls3 injectors . Car made 467 whp sae corrected .
Thanks. Forgive me for all of the questions but I'm interested and just want to make sure I know everything before I make you an offer. What castings do they use on that? 243s? And what cc is the combustion chamber?
Scott
Scott
According to your reciept, you are selling LS6 PRC Stage 2.5 heads that are made from 243/799 castings.
NOT PRC 6.0L Stage 2.5 heads, If i'm not mistaken the PRC 6.0L heads are made from 317 Castings which are very similar to the LS6 heads but with larger chambers.
However texas speed no longer sell the PRC LS6 heads due to gm discontinuing the 243/799 casting. So this is a good chance to pick up a set of PRC LS6 heads since they will be getting harder to find.
Good luck with your sell, I just thought I'd clarify that for you.
