P0121 and ASR help!
Old 06-01-2004, 08:31 PM
EliteZ28's Avatar
Default P0121 and ASR help!
I getting this code and my asr has been tweaking out. I've changed the map min and max values to 75/85 useing HP tuners and its still tweaking. I even got a new tps sensor and nothing. Could my ported TB have anything to do with it? I aint throwing any other codes exept P0121.
Thanks.
Old 06-02-2004, 09:35 AM
LS1TECH Sponsor
Steve Burger's Avatar
Do a search on this code.There is a lot of information. I ended up changing an AC sensor to fix the problem you are having. There is a lot of info on why this happens if you search on p0121.
Old 06-02-2004, 11:01 PM
EliteZ28's Avatar
Does this code tweak out the asr?
Old 06-18-2004, 02:42 PM
SAINT WS6's Avatar
I got the exact thing problem myself! Driving me nuts cuz the car starts shifting funny as well and goes into limp mode...
Old 08-29-2004, 11:12 PM
2MuchRiceMakesMeSick's Avatar
Me too, did you ever find a fix for it? Hey I live in dallas, we should race sometime
Old 08-30-2004, 06:44 AM
SAINT WS6's Avatar
It's actually being fixed right now, but from what I've heard, you just have to change the MAP min/max test parameters to like 65/85, or higher than stock, using LS1Edit. That should cure it.
Old 08-31-2004, 06:49 AM
Black02SS's Avatar
I just did this on a buddy's car and the min/max values were adjusted. Fixed his problem.
Chad
Old 09-11-2004, 12:02 PM
This seems to have fixed it, but my car surges alot now and the ltrims are way off again.
