Keeping stock HU????
Old 06-03-2004, 04:25 PM
SSInnovations's Avatar
Default Keeping stock HU????
I have purchased two sets of components and a 12" sub to replace all the speakers in my car. I have a 4ch amp for the components and a mono for the sub. I have been kicking this around but decided I would like to keep my factory HU. I cannot seem to find any info on doing this but I need to know how to wire my two new amps to the factory HU. Can anybody help me with this??
Old 06-03-2004, 06:57 PM
maddboost's Avatar
Your gonna need two line level adaptors. One for the interior speakers and one for the sub. They you wire one set to the sail panels speakers normally go for the sub amp. Then wire another to the rear hatch speakers to another one for the 4 interior speakers. Your then gonna need to run new speaker wire to the front doors and sail panel speakers. Kind of a long job but not too hard.
Old 06-03-2004, 07:48 PM
Now, The amps I have have outputs so you can connect one to another. Do I still need to use 2 Line Level Adaptors? And do the adaptors attatch to the back of the HU or somewhere else? I want to rip all the stock amp crap out.
Old 06-03-2004, 07:52 PM
maddboost's Avatar
Do you have the monsoon system? Your going to need one of each one designed for two channel for the sub and one designed for four channel. If you dont have the monsoon system they car be wired up behind the head unit. If you do have the monsoon system they will have to be wired after the amp.
Old 06-03-2004, 07:55 PM
Yeah, its the monsoon. So I guess I would have to leave the amp in. I think I might be back to the idea of getting a new HU. I really would like to keep the stock one, but I dont know that I wanna mess with all this crap. How much are these line Adaptors? Thats going to be the deciding verdict.
Old 06-03-2004, 08:57 PM
maddboost's Avatar
Probablt gonna run you around $75 for boh.
Old 06-03-2004, 10:22 PM
jimmy 2 Times's Avatar
they are gonna you crapy voltage, just trash the monsuck, but you can get the line level converter for about 23 bucs a piece at best buy
jimmy
Old 06-03-2004, 11:00 PM
Yeah, I'm thinking its going to be easier to just get an aftermarket HU. Wasnt really planning on spending the money on that though so I dont know what I'm gonna do yet.
Old 06-04-2004, 07:16 AM
tonyt123blue's Avatar
get on e-bay and find a descent hu the monsoon is not worth keeping.I tried it for about a month,and finally bought aftermarket.Made it sound 10 times better.
Old 06-04-2004, 09:20 AM
LS1thunder's Avatar
I did this with PAC OEM1 and a AOEM-GM21C for about $40 from autotoys.com. It will give you 2 sets of RCA plugs out, F&R, so no need for two line level converters. All plug and play with no cutting. I had to turn the gains on the OEM1 down from their factory settings, but that was the only adjustment I did. I jumpered the sub amp off of the outputs on my 4 channel amp with a seperate RCA interconnect or you could just use a RCA Y connector from the inputs. Do a search for Banddirector at ls1.com. He has a great writeup on his web page about doing this. And if your stock HU is working good, I would keep using it.
http://www.pac-audio.com/products/oem1.htm
Old 06-04-2004, 04:14 PM
Do I have to leave the monsoon amp in?
Old 06-06-2004, 01:30 PM
LS1Baron's Avatar
This will help:
https://ls1tech.com/forums/wiring-stereo-electronics/176569-z28-owners-get-rid-monsoon-amp-without-rewiring-whole-car.html
If your new amps have speaker level inputs, you can eliminate the monsoon amp but keerp the head unit.
