Help low mph with h/c
Old 06-06-2004, 08:59 PM
Justin99TA's Avatar
Default Help low mph with h/c
I have a 224/228 586 596 113.9 in my car right now. I only put down 379.8 RWHP before true duals and an asp pulley. My car on friday ran on the motor 12.37@110 n/a and a 11.20@121 squirting 100. Something is def not right. I have PP S2 heads ,LS6intake ,Pacesetter headers and this is all I have run. I should at least be trapping 115-116 n/a. Im going to do a compression test on the car and see what that brings.
Justin
Old 06-06-2004, 11:05 PM
00LS1SS's Avatar
I have more less the same problem. At 2400ft I only trapped 111MPH with my stock gears and street tires cutting a 2.36 60ft. It felt fast but I was expecting more.
Old 06-06-2004, 11:20 PM
greekss's Avatar
hmmm what kinda gears do u have... ya somethin is up, cuz my basically stock car is trappin 109 mph
Old 06-06-2004, 11:29 PM
jrp
SN95 Director
jrp's Avatar
what was the full slip? what were the track conditions and what were other cars running?
Old 06-06-2004, 11:32 PM
SUX2BU's Avatar
OUCH i run 119 with cam only.
Old 06-07-2004, 12:16 AM
99MONGOOSE's Avatar
Maybe a timing issue? Possibly false knock and the PCM is cutting timing, thus lack of power? Try A-tapping while running some full-bore passes and see what is going on.
Old 06-07-2004, 08:38 AM
1fastWS6's Avatar
What were the weather conditions? Pressure, humidity, temp? You can lose 3-4 mph pretty easy with bad conditions.
Old 06-07-2004, 08:55 AM
LS1TECH Sponsor
foff667's Avatar
what gears do you have now 3.73 er...?? Last time i hit the track pushing 373 to the wheels with a bogg off the line w/ my 2.73's i trapped 112 in 70 degree weather...im hoping we can fix my issues and get that mph up to 114ish...bottom line i think your #'s are off but what conditions was this in, what gears? Any noticable issues with the car?
Old 06-08-2004, 03:13 PM
Justin99TA's Avatar
I have 3:73s. Im going to ATAP the car tonight so I should know more. The weather was low humidity 75 out. I don't have the slips with me so I couldn't tell you
Justin
Old 06-08-2004, 03:17 PM
cantdrv65's Avatar
Talking
What is the elevation at the track? What did you trap there BEFORE the H/C.....If at a high elevation track thats not bad. If its in Houston that is horrendous.
Old 06-08-2004, 03:21 PM
Justin99TA's Avatar
the local airport is 799. Its not more the 1200 at the track im sure
Old 06-08-2004, 03:28 PM
Orange Peel's Avatar
Do your Pacesetters hit the k-member? If so you may be getting some false knock which can be retarding your timing, causing lack of HP. AutoTap that **** and see what the KR is and timing, may answer your question
