TA wont start
Old 06-07-2004, 05:16 PM
Rchumsae's Avatar
Default TA wont start
car has been runnin perfect and today i went out to Burger King and when i came back out to my car to go home, the car didnt start at all. the motor didnt even turn over, no clicking, nothing. I checked fuses and the battery and both are good. I thinkin maybe its the starter or suttn stuipid like that little clutch sensor but i cant find it. Please gimme some ideas guys, thanks.
Old 06-07-2004, 05:24 PM
TeamZ's Avatar
did u check the battery cable i know on my car i have to scrub the positive cable w/ a wire brush every once and awile..
Old 06-07-2004, 06:02 PM
XtinctHawk02's Avatar
another vote for the battery.
Like what TeamZ says, clean your battery connectors, probably alot of crud on the connection.
Old 06-07-2004, 06:04 PM
TeamZ's Avatar
also if u have a monsoon system i hope u know the code to get your radio working..lol
Old 06-07-2004, 06:06 PM
Rchumsae's Avatar
what makes you think its the battery?? btw, i got home cuz i was kinda parked on a hill and i popped the clutch to start it. I tried jumpstarting it when i got home, it doesnt do ANYTHING. and how am i supposed to test the starter when its still on the car? i dont see ANY wires on it, uhhhhh.......thanks a lot for the help guys, i need a resolution fast.
Old 06-07-2004, 06:10 PM
TeamZ's Avatar
did u check the battery cables.. i know every 6 mths my car does the same thing and i have to scrub all the crap off the end then it starts right up
Old 06-07-2004, 06:56 PM
silverZ98's Avatar
does everthing else come on in the car lights and gauges? if so does your secrety light on the dash come one? if its on it will not start or even try to turn over had this problem last week so i by passed the vats system. to learn more on the vats do a search there is alot on here about it
Eddie
Old 06-07-2004, 06:57 PM
SmokingWS6's Avatar
If he pop started the car then it cant be the cables, he had enough current for the pcm, fuel pump, ingnition ect to pop it. Battery could still be low, or dead starter ect.
Old 06-07-2004, 07:50 PM
Rchumsae's Avatar
no, the security light isnt on. I tested the starter and it works fine. i bought a new clutch saftey switch but cant find where the hell it goes??
Old 06-08-2004, 09:55 AM
02 WS-6's Avatar
do you have two keys for your car? if so try the other key, my did the same thing when I tried to start it, it wouldn't do anything, tried it like 20 times, and then finally got it to start, then about a week later it did it again at home, tried my other key, and it started right up, I guess that little electrode or whatever it is on the key got wore out or something, but now I have no problems at all...
Old 06-08-2004, 03:22 PM
Rchumsae's Avatar
nah just one key
