Who sells rocker arm bolts? GM dealer wants $5 per bolt
Old 06-07-2004, 07:05 PM
benningtonz28's Avatar
Default Who sells rocker arm bolts? GM dealer wants $5 per bolt
I am replacing one broken bolt and decided to just replace all the bolts while I am have the covers off. Who sells m8 x 1.25 bolts for less than the $5 that the dealer wants?
sears has some hex headed bolts that are 14grade strength, but these bolts are threaded all the way up to the bolt head, unlike the stock(12grade strength) bolts which are threaded up to the point where the bolt meets the base of the rocker arm.
Old 06-07-2004, 07:16 PM
ss rally red's Avatar
I can get you GM rocker arm bolts for 2.50 ea. brand new in the bag. Let me know.
Old 06-07-2004, 07:48 PM
LS1TECH Sponsor
foff667's Avatar
you can check out www.gmpartsdirect.com as well
Old 06-07-2004, 09:31 PM
2xLS1's Avatar
Because of the strength of the bolt and the built in washer on the head, I think I would stick with the GM bolt. And any dealer that sells parts for MORE than the GM List Price should be told to go F**k themselves. Most decent parts men will sell wholesale if you ask them and do a reasonable amount of business with them.
Rocker Arm Bolt - 12560961
Dealer List - $3.84
Dealer Cost - $2.19
Old 06-07-2004, 11:22 PM
DOC OTIS's Avatar
I got a brand new set I'll sell you for $30. Switched rockers and don't need these anymore. Let me know.
Old 06-08-2004, 02:17 PM
robertbartsch's Avatar
rocker arm bolts are NOT torque-to-yield; right?
Old 06-08-2004, 02:19 PM
technical's Avatar
22 ft/lbs and you're done.
Old 06-08-2004, 02:58 PM
Scalpel's Avatar
Correct. They are NOT TTY (torque-to-yield) bolts thus you can re-use them
Quick Reply: Who sells rocker arm bolts? GM dealer wants $5 per bolt
