who's using a power invertor to power laptop?
Old 06-16-2004, 01:46 AM
0rion's Avatar
Default who's using a power invertor to power laptop?
What brand if any are you guys using and have you had any problems with running them while logging?
Old 06-16-2004, 05:39 AM
Plan B's Avatar
Mine came with the Laptop.... COMPAQ Presario 1500... The numbers say 386501-002 Rev A... I bought it a while ago.... No problems yet!
Old 06-16-2004, 08:20 AM
Moderator
jimmyblue's Avatar
I use a little 70W cigaratte lighter one I got
at AutoZone and it works fine (only fits in the
lower lighter though, too much of a pecker to
fit by the shifter).
Old 06-16-2004, 09:08 AM
chadtn's Avatar
I picked up the highest rated one they sold at Wal-mart...No problems so far.
Chad
Old 06-16-2004, 11:58 AM
Brains's Avatar
Got mine from Sams club .. 700 watt peak, powers the laptop and anything else I plug in to it
Old 06-16-2004, 12:02 PM
ataylors's Avatar
Hey can you run a showtime rotisserie with that too?
Old 06-16-2004, 02:55 PM
Brains's Avatar
Find me one and lets find out
Old 06-17-2004, 01:12 AM
0rion's Avatar
No ground loop problems with any of these? Have you guys heard of anyone having a problem with ground loop killing their a-tap cable?
Old 06-17-2004, 10:58 AM
critter's Avatar
My personal preference (after having used inverters) is a 12V laptop car adapter (or some such verbiage - google for it). The one for my Toshiba cost ~$40, cheaper than buying a battery to replace the toasted one and will run the laptop much longer They are more efficient than an inverter, but that probably isn't a big deal in this application.
Old 06-17-2004, 02:41 PM
Brains's Avatar
No ground loop problems with mine at all.
Old 06-18-2004, 05:14 PM
Cheatin' Chad's Avatar
I have a tripp lite 800w and it has worked great for a couple of years. I use it at work mostly.
Old 06-18-2004, 09:49 PM
0rion's Avatar
Thanks for all the replies. That's what makes this forum so great. You ask a question and several people take the time to answer it.
Old 06-19-2004, 02:06 AM
Loco's Avatar
I bought a Belkin from Compusa for around $30 and it works great.
Old 06-24-2004, 06:29 AM
gomer's Avatar
I killed my Atap cable with my walmart inverter. I emailed the Atap tech support and below is the email I got back from them. I haven't had the ***** to try and run the inverter again while connected up to my Atap cable.
Scott
Sometimes when people charge there laptops from a cigar lighter they will have different ground potential than the vehicle. When that happens there is to much voltage going through the scanner. In order to get it repaired you will need to talk to Jane at 815-433-5100 ext 218.
Regards,
Javan Sheneman
Old 06-24-2004, 11:21 AM
0rion's Avatar
Scott, do you remember the brand name of that invertor? I bought one from Best Buy and have used it a couple times and it seems to work fine but you know how that goes. It works fine for a while then out of the blue "pop".
Old 06-24-2004, 01:51 PM
ROCNDAV's Avatar
I was wondering the same thing. I drove up to mamoth this winter (7 hour drive) and hooked up my Laptop and FM transmitter to a Coleman 400W inverter when the laptop's battery died. (Yes, I know...poor man's IPOD). Wow there was so much noise coming through the audio system. I have been wondering if it was possible to do the same for programming, but also wondered if anything could happen to either the ECU or the laptpop. :S
D
Old 06-24-2004, 04:25 PM
AgentOrange's Avatar
Chad
same here..
