What map value denote
Moderator
WOT threshold shows as 94% TPS, this is a value box
you can change in HPTuners.
PE threshold on my car is set to MAP=15kPa stock.
That's a pretty low threshold to start enriching(?).
It does not discriminate WOT per se. There are PE
modifiers for other things, that I haven't gotten to
understanding yet.
I would like to build a model that combines all of the
"enrichment actors" and lets you see the true
enrichment response (between open loop A/F, the
various PE tables / modifiers, etc.) across the RPM,
MAP, TPS, MAF inputs. It seems conceptually messy
to me right now. Like PE vs RPM, without comprehending
MAP, seems like a pretty misguided enrichment basis
what with MAP or CylAir being the key burn rate
factor.
understanding yet.
factor.
Originally Posted by HumpinSS
the beginning of WOT
WOT, as jimmy says, anytime above 15kpa. Look at the WOT/Cold table - defined as TPS percent and RPM.
Here's an interesting thread with some good info on WOT http://www.efilive.com/forum/viewtop...er=asc&start=0 FWIW. How's the Monster cam??
joel
The monster cam is killing my *** trying to tune but i will prevail and work this out. I broke donw and bought HPTuners because of lost PCMs so I wont be tuning till i get it
I'm sure you will progress quickly with HP Tuners . Keep me posted.
joel
