Where to order all parts for 9" rear? (unassembled)
Old 06-21-2004, 04:10 PM
guadofreak's Avatar
Default Where to order all parts for 9" rear? (unassembled)
Looking to possibly upgrade from the 10 bolt and it seems the 9" is the cheapest and strongest out there.
Who can I buy all the stuff from including the F body modified 9" housing(iron is fine) and all the parts, axles, bearings, locker etc...
Just seeing how much I would save myself in putting it all together once I have all the parts. Thanx!
12 bolt would be nice but after all my reading etc... it will cost me alot in the long run and I like my clutch dumps so the locker and 9" would be my best bet.
Old 06-21-2004, 08:11 PM
guadofreak's Avatar
i know you people are out there! most vendors only deal with the 12 bolts...
Old 06-21-2004, 09:49 PM
SUX2BU's Avatar
9" strongest....YES
9" cheapest.....NO
Just go to www.moserengineering.com
Old 06-21-2004, 10:34 PM
guadofreak's Avatar
just looked a little more I was looking at 9" with spools.
But the 9" is I think the preferably way to go due to the easy of changing things etc...
Old 06-21-2004, 10:50 PM
SUX2BU's Avatar
go with the spool if you never wanna worry about your posi breaking.(thats the only thing that ever breaks in the big boy rear ends)
Old 06-22-2004, 12:02 AM
Squintz Palladoris's Avatar
Have you seen the new diff from Tratech? I think it's called a truetrac. It is a torsen style diff . I talked to a guy at the moser trailer when I was at the Southern Nationals and he said it is supposed to hold 750hp.
I am running a locker with a very stiff spring. It makes alot of noise makin turns in parkin lots but I am not worried about breakin spider gears on a 6000rpm dump.
I peiced together my 3rd member from ebay. Except for the gearset and pinion support which I got from Jegs.
The housing is from Billingsley and it is not bulletproof.
It's BOMB PROOF!
