LS6 Heads??
8 second mod
cool, i was thinking around 330. thats sweet. I take it that is the heads that made 502?? that is some nice power!!!!!!!!
how much more power will the ls6 meke over done ls1's?
As many have said in the past, a lot depends on the testing equipment. I have MTI stage II LS6 heads that flowed just under 315 at 650 on a stock bore. They are about 2 years old.
Originally Posted by kumar75150
from what I have seen, flow numbers dont necessarily mean that much
Mine only flowed 309 at .600 lift and my car seems to be running/dynoing ok.
IMO "balance" is key word. Do my heads "balance" my set up.
8 second mod
Yhea, im using heavy valves and looking for a nice flow like predator said, to balance it out. I want the best heads for what im looking to do. Im just doing a little research, to make sure of my self. But it seems most guys have the best luck with the ls6 head, nothing wrong with the ls1 head, but seems ls6 does have a slight advantage if done properly.
Thanks for the input, keep it comin.
