Something broke
Old 06-22-2004, 05:58 PM
BDD
BDD's Avatar
Default Something broke
I installed a camshaft about 1000 miles ago and now I have this loud tick noise. The weird thing is I pulled the valve covers to look at the springs and they were ok so I put everything back to gather and it started up and didn't tick at all. So I take it for a drive today and the thing starts ticking about a block away from home. I don't know what is going on. Can anybody give me there guess on it.
Old 06-22-2004, 06:13 PM
pacmantravis's Avatar
Bent Pushrod <----See if the car falls on its face at high rpm's
Spun Bearings <---What I had. It got louder as the car got warmer.
Fuel Injectors
Piston Slap
Old 06-22-2004, 06:19 PM
BDD
BDD's Avatar
my guess is a collapsed lifter.
Old 06-23-2004, 05:14 PM
BDD
BDD's Avatar
Does anyone else have an opinion
Old 06-23-2004, 05:22 PM
mitchntx's Avatar
Sometimes a broken double valve spring is tough to spot ...
Old 06-23-2004, 06:16 PM
ktmrider's Avatar
Lifter problem IMO. Collapsing at higher RPM's and/or the oil passage is plugged. May have happened when you installed cam and rotated the lifters up in the holders.
Old 06-23-2004, 06:33 PM
INMY01TA's Avatar
Ticking is normal for a cammed car. Not all will do it, but it doesn't necesarily mean anythings wrong. Do a search on "tick" in the internal section. You should get about 4 pages of info to read. You'll hear everything from bad lifters to spun bearings to "normal". Mine's done it since my cam install and I don't acknowledge it anymore.
Old 06-23-2004, 07:16 PM
slyws6's Avatar
werd, these engines with their non adjustable rockers tend to be louder than normal especially with an aftermarket cam.
-Sly
Old 06-23-2004, 07:33 PM
BDD
BDD's Avatar
I know these engines tick and mine always did, but now my engine makes a loud tick from #7 cylinder. Also it will backfire when I give it a little gas at like 2500 RPM through a stock catback.
Old 06-23-2004, 07:34 PM
slyws6's Avatar
hmm interesting, pull the pushrods out on that cylinder and check them out.
-Sly
