Drag Racing Tech - Line lock probs w/ slicks
ONYXSS
05-05-2002, 08:05 AM
Today at the track, I had problems with the line lock holding the car. The car would squirm sideways before holding the tires, and once didn't hold at all resulting in no burnout (wouldn't you figure that was the qualifying run for quick 8.....luckily I still qualified after spinning through 1st)
Thanks to a tip from Fireball, the key is to pump the brakes just before applying the lock. I never had to do that on Et Streets, but it really helped with the slicks. Just thought I'd pass it on for anyone with similar problems.
CHRISPY
05-05-2002, 08:22 AM
thanks for the info!
Cheers,
Chris
Fireball
05-05-2002, 08:46 AM
did that hold it completely still?
All I do it push once hard on the brakes and hold them.Then I hit the momentary switch and release my foot off the brakes.
Then go do your BO.
Car shouldnt move
JS
ONYXSS
05-05-2002, 11:58 AM
Fireball - yes
JS - that's what I normally do, but it didn't work yesterday. Pumping first worked great.
Ebbsnflows
05-05-2002, 04:53 PM
Dave....man I wish I could spin and still pull my wheels a foot off the ground! You had some AWESOME launches yesterday!
Coach 02 A3 Z/28
05-05-2002, 06:00 PM
I pull through the water. Just to the edge of the water box, pump the brakes 1 time then push the button,(linelock) pump the brakes a couple more times then do the burnout. It holds from me every time.
Just my 2 cents.
Coach 02 Z28 M6 Drag Racer <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Mod's: Almost Finished <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
chevyguy3
05-05-2002, 07:04 PM
i never have a problem at the track in the water box with just pushing the pedal down and hitting the line lock, but when i have to do dry burnouts on the street i have to pump the pedal again after the lock is on to get enough pressure to make it hold in place
ONYXSS
05-05-2002, 09:29 PM
Thanks, Ebbs. Several people said the wheels were up in the air. Kinda hard to tell in the car........
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
