Stereo & Electronics - Those whith subthump t-top box.....
Frontman
06-25-2004, 12:17 AM
Is there room for this amp http://www.mtxaudio.com/caraudio/products/amplifiers/thunder1501D.cfm to fit underneath the box. It will have to be angled so i can still put the t-tops in.
megabass
06-25-2004, 09:59 AM
It'll be close, but will work. Any amp over 10" won't work, but this one is only 9-3/4". Like you said, you have to angle it. Keep it high in the back and angled down at the front and you won't have any problems.
Frontman
06-26-2004, 08:00 PM
How far down do the t-top boxes go? Do they just rest on top of where the stock t-top holders are?
megabass
06-27-2004, 09:40 PM
Mid shelf level. So yes, right above t-top holders.
01 ls1 z28 DA BRONX
07-03-2004, 03:15 AM
i'd like to see some pics of the amp rack you make for this set up, as i have the same set up
Frontman
07-03-2004, 06:15 PM
if you're talking to me it's gonna be about a month or so before i get my setup installed. Got to save up for the IDMAX's ya know. :hail:
01 ls1 z28 DA BRONX
07-04-2004, 01:57 AM
its all good, my camaro is at the stealership cuz of 3 spun crank bearings ( warranty ).. i'm just trying to figure out what would be the best way of installing the amp
megabass
07-04-2004, 08:15 PM
Well, here's a shot of my amp rack. This version is not t-top box compatible. But if you were to tilt the amp the other direction and leave the front couple inches clear, then it would work just fine. I have all my wiring and my cap hidden underneath the amp fyi. But something similar would work for the t-top box. And no, my amp doesn't overheat, despite being directly under the box.
http://www.subthump.com/images/Ampracks/RFracks2.jpg
Frontman
07-05-2004, 12:39 AM
Very clean, nicely done. :cheers:
Silver98camss
07-07-2004, 01:13 PM
my suggestion is go with the millhouse box, and a back wall amp rack. keeps everything clean, and when the t-tops are on no one can see your stuff. JMO gl
Frontman
07-07-2004, 03:48 PM
The millhouse box doesn't hold 12's. I was going to go either with a single adire brahma or an IDMax.
megabass
07-07-2004, 08:57 PM
Here's a recent t-top box I did for a single 12. Right now it's got a type R in it. But eventually will have a brahma in it. The install's not quite finished as you can see. But the formula logo is pretty cool.
02Z28LS1
07-07-2004, 10:34 PM
Type R? What, is that a ricer sub or something? ;)
J/K, I know what it is....nice setup by the way, although I would try to hide that amp for stealth
megabass
07-08-2004, 05:27 PM
You had me going for a second :jest: But yeah that amp is small enough to go under the box.
Frontman
07-09-2004, 02:37 AM
Well i guess this thread was all for not. I've decided to go with a stealthbox instead of the t-top box. Before i didn't think i could get the brahma in there with enough air space but i checked with adire and subthump and it's all good. 1 12" Brahma + 1000 watts of clean mtx power = :eek2:
Silver98camss
07-09-2004, 03:13 PM
the Millhouse box does hold 1 single 12" sub. The other good choices are the stealth boxes on the sides. The other t-top boxes look like you will scratch up your t-tops..jmo.. good luck
