Drag Racing Tech
11.55@116 with H&C, is this low MPH?
Old 05-17-2002, 10:56 AM
Black Sunshine/ 00SS's Avatar
Default 11.55@116 with H&C, is this low MPH?
I understand that it is a different time of the year, but that is what I got with the car last year, before H&C, although a few lbs lighter last year, and it was colder last year. This run was with temp about 70, and car about 3400-3450. I'll have to weigh it to be sure. It just seemed low to me.
Old 05-17-2002, 11:16 AM
D(irecto)r Pepper
Raughammer's Avatar
Default Re: 11.55@116 with H&C, is this low MPH?
Normal MPH for an A4 that is running 11.5
(IMO)
Old 05-17-2002, 11:18 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Seems low to me. I ran 12.24 at 114 with a stock motored 02 Z28 in March 2002.
Maybe some else can help you out. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 05-17-2002, 11:37 AM
LS1Tech Co-Founder
Nine Ball's Avatar
What heads/cam setup are you running? Have any dyno figures or tuning done?
Tony
Old 05-17-2002, 01:24 PM
SSU Moderator
RyanJ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>What heads/cam setup are you running? Have any dyno figures or tuning done?
Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 05-17-2002, 04:08 PM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
<strong>Some of the best bolt on cars make the most mediocre head/cam cars. Not sure why.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Because they are comparing winter killer weather to summer conditions. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 05-17-2002, 04:23 PM
Mike Hoffpauir's Avatar
I ran 11.60's@116 so I'd say the mph mates up correctly.
Black Sunshine/ 00SS didnt you have a 3200 pound raceweight when you went 11.49? Do you know the DA at that time? What was the DA for these times and mphs?
Old 05-17-2002, 05:32 PM
kent's Avatar
Base upon this time of year even with H/C job, your times seem to be well within the range. My car runs anywhere from 113 to 117 depending upon weather mostly and wheels I am running at the time. My fastest MPH is 117.75 for the quarter. I am hoping to go higher by Porting and Polishing my throttle body and removing a little weight off of my car. With the times listed above, the only weight reduction was spare tire and jack and running skinnies. I believe in the right weather, faster 60' time, little weight reduction, and a little tweaking--the car is capable of 117-119 range. Hopes this helps.
Old 05-17-2002, 11:04 PM
msce2b-dustin's Avatar
Just curious what your 1/8 et and mph was along with 60 ft.
Thanks
Old 05-17-2002, 11:22 PM
Orange Krush's Avatar
My E.T.s are a bit low but I blame it on the street tires ! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old 05-18-2002, 12:50 AM
98TAauto's Avatar
Well when i was running 110 traps and sprayed a 75 shot in 2-3 i picked up to 116 so your MPH is about right to me.
116-118 is about average for a A4
i only trap 112-113 now with stock internals
weather will have a big role in your MPH this time of the year also! more than likely around fall you would see 118 or better
Old 05-18-2002, 12:55 AM
Terry Burger's Avatar
Old 05-19-2002, 07:14 AM
Ragtop 99's Avatar
You need to dig up the weather conditions for bolt-on run and the current run and estimate the change in DA. How did the 60' & 1/8 compare?
If the air was good on your H&C run, I'd say you're a bit low. If it was warm & humid you're fine. Have you done any tuning yet? Can be .1 & 1-2 mph there.
Old 05-19-2002, 07:50 AM
CHRISPY's Avatar
I think you need to look at weather as well.
I had a great day yesterday (DA around 1000feet which is awesome for St. Thomas) and ran 4 122mph passes and a traction limited 11.78 ET (1.79 sixty)
Have you dyno tuned the car?
Cheers,
Chris
Old 05-20-2002, 08:59 AM
We have been getting alot of rain up here. I dont know what the DA was for that day, but it was the first nice day we have had, so I went. I'm still learning about the DA thing, and how all that relates. If it's nice out, & the car is ready, I go racing...
Other guys there said their times were down also. So, I guess I still need more testing to figure this thing out. Dont worry Terry, this mediocre head & cam car will pull 10's on motor, by the time I am done.
I am running ARE stage 2 heads, & TR 224 on a 112. Just had wideband dyno tuning, before the track times, & pulled 380 HP with great A/F ratio, & then pulled 480 with a 100 shot, that we managed to jet up to be a bit rich, to be on the safe side. 0 KR. The graph looks good, but I think there is more there somewhere, so time to get more schooled with LS1 edit, & bring it out.
I'm going to weigh the car today. It is def heavier, but not by a tremendous amount. I could drop another 100 lbs of her, easy. Might do that next time, then just be satisfied with 10's on spray, until the cold & dry weather gets gets here. Thanks for the tips everyone. Project 10 sec NA goes back to the drawing board...
Old 05-20-2002, 09:36 AM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
A good density altitude calculator to use is http://rshelq.home.sprynet.com/calc_da.htm. It takes into account actual altitude. You can get historic weather conditions at www.wunderground.com. The DA for me yesterday calculates to just a hair over 1,500', and I ran an 11.66 @ 116 MPH with a 1.638 60' time. I could've had 11.5's if it would've hooked! The raceweight was 3,510#, and I'm running stock heads w/ the Comp XE-R 224 cam on a 112 LSA. It sounds a bit low to me, but I'd like to see your DA first. Was the 380 RWHP locked or unlocked? I managed 361 RWHP unlocked and 380 RWHP locked, FWIW.
__________________
Old 05-20-2002, 11:01 AM
The 380 was unlocked. I'm going to make up a lockup switch, for tuning purposes.
