oil in throttle body and intake
Old 06-30-2004, 04:32 AM
merlinsrealm's Avatar
Default oil in throttle body and intake
I took off the air intake last night and saw oil laying on the throttle body and laying in the intake....what can I do to clean the oil out without taking the intake off? what might cause this? I have 24000 miles on the engine and wasnt there about a month ago....
Eric
Old 06-30-2004, 05:36 AM
PREDATOR-Z's Avatar
GM top end cleaner for intake.
Dry rag an some gas for TB.
This is a by product of the wonderful PCV system LS1 has.
Catch can will remedy or dramatically reduce.
Old 06-30-2004, 08:19 AM
Unforgiven1's Avatar
Yeah definitely run some top end cleaner though the PCV system. An alternative to the aforementioned GM cleaner would be Seafoam which I believe can be bought at your local O'Reilly's and other parts stores. Definitely check with our sponsors AMW about their PCV oil catch-can to prevent that from happening again.
Justin
Old 06-30-2004, 11:38 AM
LS1TECH Sponsor
foff667's Avatar
as long as it doenst look like this
Old 06-30-2004, 11:52 AM
plumbr's Avatar
I also agree with the top end cleaner and catch can for the pcv system. It has dramaticly improved my similar problems.
Old 06-30-2004, 12:28 PM
2000Blackout's Avatar
Ouch that dosent look good!
Old 06-30-2004, 01:58 PM
mooleyz28's Avatar
What would cause this to happen?
Old 07-01-2004, 11:46 AM
Mike22ca's Avatar
When all this oil is getting into the intake and the throttle body, when you guys get on it does it smell like you are burning oil? I'm wondering if I have the same problem. When I get on my car though it smells like I'm burning oil.
Old 07-01-2004, 11:47 AM
LS1TECH Sponsor
foff667's Avatar
It's slys old motor...rod let go lol
Old 07-01-2004, 12:54 PM
Buckmaster's Avatar
The incredible CRAPPY PCV system on the LS1 and the enormous amount of vacuum present. These SYSTEMS SUCK on the LS1. Quite a joke actually.
Old 08-23-2008, 08:36 PM
CLARKSLS1SS's Avatar
i had oil in front of plate on throttle body, puddle in my smooth bellow and on the top inside of my lid, whats the cause of this? and i do have a catch can?
Attached Thumbnails oil in throttle body and intake-throttle-body-001.jpg   oil in throttle body and intake-throttle-body-002.jpg   oil in throttle body and intake-throttle-body-003.jpg   oil in throttle body and intake-throttle-body-004.jpg   oil in throttle body and intake-throttle-body-007.jpg
Old 08-23-2008, 08:57 PM
t t t
Old 08-23-2008, 10:42 PM
Blazingz28's Avatar
Originally Posted by CLARKSLS1SS
t t t
k&n filter over oiled?
Old 08-24-2008, 12:50 AM
No theres no oil on the filter and hasnt been for like 40,000miles, the problem just started today, it was worse before i took the pics, there was actually a puddle laying in the smooth bellow, the first time i cleaned it all, drove 40 miles and it was back to the puddle of oil....i think it may be coming from the hose that runs from the valve cover to the top of throttle body then seeping through the hole that leads to the front of the throttle body and running...but my question why did it just start today and not notice it ever before? Thanks any suggestions are helpful
Old 08-24-2008, 09:32 AM
More pics
Attached Thumbnails oil in throttle body and intake-throttle-body-008.jpg   oil in throttle body and intake-throttle-body-009.jpg   oil in throttle body and intake-throttle-body-010.jpg
Old 08-24-2008, 10:34 AM
KrisXpc's Avatar
Id say its the PCV. There are PCV delete kits with a breather.
Old 08-24-2008, 07:46 PM
Whats all involved with the PVC delete kit (pics?) and where can that be bought at? But like i said it just started 2 days ago, why haven't i seen this before? Thanks
Old 08-25-2008, 01:02 PM
t t t
Old 08-26-2008, 08:01 PM
Bump ttt
Old 08-27-2008, 07:05 AM
t t t
Quick Reply: oil in throttle body and intake
