4L60E Stuck in Fwd AND Rev!
Old 07-06-2004, 07:43 AM
cropduster's Avatar
Default 4L60E Stuck in Fwd AND Rev!
Tranny is only 1 month from the shop after being rebuilt. Driving along and it seems like the brakes are dragging. Did a little troubleshooting and found out if I put it in Neutral it rolls fine. Put it back in any gear and the harder I accelerate, the harder it holds back. By the time I got it home (shoulda towed it), It was taking 3-4K RPM to get it up my inclined driveway. Talk about a burnt smell!! I drained some fluid out and you should have seen the pretty colors! It looked like that color changing paint. Aluminum. The shop's gong to replace the tranny but I was just wondering if anybody knew what could have happened? Just wanted to satisfy my curosity.........
Old 07-06-2004, 08:06 AM
Jeff406cid's Avatar
Did you have any codes? Are you sure it wasn't starting out in 3rd gear(loss of electrical power, or bad 3-2 solenoid), making it feel like the brakes were dragging? Eventually it will burn the trans out.
Old 07-06-2004, 12:11 PM
Ragtop 99's Avatar
Maybe they gave you their secret prototype 4L60e transbrake.
Good to hear that the shop is taking care of you.
Old 07-06-2004, 01:32 PM
cropduster's Avatar
No it shifted fine, just severely dragging.
I did get out today and talked to another tranny shop and they something about welded planetaries. Never heard that one before now. I checked and my cooler lines ARE clear but with all that metal it's gonna take a LOT of flushing, maybe even replacement of my aux cooler.
Old 07-06-2004, 02:04 PM
94form2000z's Avatar
Sprag
or at least your symptoms match those I had when mine went.
Old 07-06-2004, 03:39 PM
SDB
SDB's Avatar
Damn, a free transbrake,,,find the tranbrake button and launch that bitch!
Old 07-08-2004, 02:22 AM
Jeff406cid's Avatar
If you place it into manual first did you get the same syptoms?
Old 07-12-2004, 08:03 AM
cropduster's Avatar
Yeah, all fwd gears are affected, reverse was too just not as bad. Probably because of the gearing.
