TH400 guys with spray, what converter to get?
Old 07-26-2004, 04:08 PM
MeanWS6's Avatar
Default TH400 guys with spray, what converter to get?
I will be spraying between 150-250 on my TH400, what converter should I go with. Currently have 3600 stall, but was thinking of getting a 4000 stall - or should I keep it in the 3K range?
Old 07-26-2004, 08:34 PM
theblur98ss's Avatar
I bought a converter off a guy with a similer setup and I plan to run the same thing and I'm using a yank pt4000
Old 07-27-2004, 11:44 AM
MeanWS6's Avatar
I was asking, because I was told that a 4000 converter would flash to 5000 on a large shot
Old 07-27-2004, 04:43 PM
Roadrunner 45's Avatar
Do you drive your car a lot? 4000 seems like a lot of converter without lockup?
I'd like to know too- I just ordered a TH400 and went with a 3200-3500 stall- now I wonder if it'll be too small (224 cam,headers, NX 150 wet, 3:73 12 bolt, 26" tire), but that what was recommended to me by two different converter mfr's. It seems the general consensus was to keep the stall lower for a n2o car than a n/a car?
Old 07-28-2004, 08:33 AM
The Bull
DERTY's Avatar
A 4000 will flash to 5000-5400 depending on the manufacturer of the converter. Obviously that is something they can help you with. I have a Neal Chance 4000 stall and it flashes to 5200 on a 200 shot and a little higher yet on a 300 shot. Unfortunately I was too busy looking at the sky instead of the tach, so I couldn't tell you exactly what it flashed to.
Old 07-28-2004, 11:24 AM
MeanWS6's Avatar
so is 4K too much, or should I drop down to 32-3600 for a 200 shot
Old 07-28-2004, 11:51 AM
The Bull
DERTY's Avatar
I like my 4000 stall converter. It is pretty cool actually, even on the street. It's all personal judgement after that. Are you going to do more street driving vs strip, etc. If that's the case you may want a lower stall speed. If that's not the case and you'd like something that's reasonable yet aggressive all around, go with the larger stall.
Old 07-28-2004, 02:44 PM
8 second mod
Noyzee's Avatar
im saying lower.4k is to high, but i may be wrong
Old 07-29-2004, 07:15 AM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
I have an ATI 4000 that flash stalls to ~4600 on a 150 shot.
