TREX cam for stock heads
King of Pigskin Knowledge
Put in the Patriot Gold dual's for my T-rex. Just finished the rod bolt install tonight, so everything is still torn apart.
http://community.webshots.com/album/158370128KBrCmy
trex cam what is the best head for this cam?
[i have a 2002 ws6 and i have bought a trex cam with comp dual springs and am thinking of buying either afr heads or going to bowling green and having a set of 5.3 heads ported and having the pistons fly cut,how much more power will this give me than just using the stock heads?
Originally Posted by SMOKIN01TA
i dynoed mine with cranes and compared it to a identically set up car with comps, the cranes with .030 shim carried out better. im spinning it up to 7200 with no problems
Smokin how many pounds inj. you runnin with that bad boy?have 28s right now.wondering it would be enough.thanks.
I'm not SMOKIN, but, I run the SVO 30# inj (36# really) at 63 PSI with my Trex setup and it runs between 82-88% duty cycle at WOT. Thats on a 430 RWHP A4, I'm betting you are close to running 100% at WOT on the 28# inj. You have auto tap or EFI Live?
Dan
Dan
