Piston swap, engine still in car??? 2001 C5
I know this info is here but I cannot find it with the search engine....
I want to pull the pasenger-side front piston with the motor still in the car. Is there a way to drop the oil pan and get to the rod bolts??? Have head already off and then push piston out top, without pulling the motor???
Is this possible and if so what kind-of nightmare and I am headed for????
Thanks,
Thanks,
it can be done on the F-Body's, so I'm sure it can be done on the vette but not positive. You will have to drop the k-member under the engine while having a jack hold the engine up. From there you can remove the oil pan, remove the passenger head and then you can pop the piston out of the top after removing the rod bolts. Been done before , I don't think it would be that difficult if you have the proper equipment to hold the engine up.
-Sly
-Sly
King of Pigskin Knowledge
Just did the rod bolt upgrade in my car (f-body), should give you some idea of what you need to do, IF it's ok to just swap out the rod/piston, here's a little write-up...
https://ls1tech.com/forums/showthrea...95#post1614995
From what I heard, the k-member on a C5 is not in the way of the oil pan, which would make it MUCH easier. But I've never been under a C5.
Ok.....
What about if I look at it from the top.... Just for arguments sake, assume the heads are off the engine can I pull the engine from the top????
Thanks
Thanks
Originally Posted by SideStep
Ok.....
Thanks
Thanks
Ok.....
Thanks
Thanks
Originally Posted by term
I just pulled my short block out the top with heads off, it will be going back in the top in a few days.
