Dyno'd the 99 Corvette FRC today :)
I decided to add the new Halltech Stinger Air Intake System and she put down 331.5rwhp/346.3rwtq on the second pull. The only other mod on the car is Borla Stingers. The #'s seem kind of high to me so I checked to see if I had an ls6 intake and the #'s I pulled off the intake were 12556333. I cant seem to find those #'s on GM parts anywhere.
Great numbers! If you have EGR then its the LS1 intake. One question is if this is corrected numbers or not. SAE numbers tend to lower actual numbers here in the NW 10-20hp.
Now that I think about it I can't recall ever seeing the standard EGR system like on the Fbody on the C5. Wonder what the difference is between your manifold and the LS6 if anything?????? Regardless, those are some awesome numbers!
Originally Posted by VINCE
It seems I have found another factory freak
Senior Member
Thanks guys.. Coastal Chassis and Dyno is where I dyno'd the car. I will dyno with the 408ci here as well
Originally Posted by Rays C5
Very good #!!! I can't figure out why mines are so low?BTW I have a factory freak also......it has to have been the slowest c5 I've ever seen!!!
Originally Posted by ccajun4real
Dyno #s and time slips sometimes do not jive. It is weird. I dynoed at 329 HP and 321 TQ and run 12.6@113MPH with 19"s Continental street tires with a 1.95 60ft. I truly think different dynos give different numbers but I dont know enough about the inner workings of the dyno to be sure.
