TTP Equalizer V.1 Cam Only - 447rwhp/414rwtq
This is Michael4034's car, one of our customers and friend. His mods are as follows:
- Stock LS6 Motor (LS6 heads, bottom end)
- TTP Equalizer V.1 Camshaft
- 90mm LSX Intake w/ FAST 90mm T/B
- Kooks 1 3/4" LTs w/ ORY
- Borla 3" Catback
- Mez Elec Water Pump
- ASP U/D Pulley
These numbers are rolling through a Moser 12-bolt with 4.11's. Full belts, through the y-pipe/catback. No dyno tricks running on 275 nitto drags.
- Borla 3" Catback
- ASP U/D Pulley
The car makes awesome power. We saw a gain of 8rwhp and 11rwtq over the 78mm setup.
Old 220 cam with stock waterpump and ASP U/D Pulley
Same setup as above, except with a 78mm LSX w/ stock ported throttle body
The cam is decently big but we have customers using it in their daily drivers.. Specs are not public nor is the cam. You can only buy the cam if you install and dyno tune with us.
