Headers installed... but
Old 08-11-2004, 07:11 PM
99SSinOC's Avatar
Default Headers installed... but
I just installed my longtubes and drove it down to my buddies shop and had the custom Y put on without cats... but now my Oil pressure is lower as well as the temp being higher.. both can obviously conflict each other (High temp = low oil pressure with thin oil (5w30 M1).) Anywho, I'm just wondering, is this normal? Or should I get a new T-stat? 180? It's running at just over 210.. with according to the stock gauge. Any insight would be much appreciated though!
Thanks,
Garrett
Old 08-11-2004, 07:13 PM
Keenov's Avatar
Never heard of that. Only thing I noticed was idle was a little lower than stock.
Old 08-11-2004, 07:18 PM
99SSinOC's Avatar
idle is fine at around 600 out of gear and 500 in gear...
Old 08-11-2004, 10:32 PM
zchgla's Avatar
600, and 500!? is that just me or is that really low? mine idles at 1k...
Old 08-12-2004, 01:07 AM
kpowr82's Avatar
In park you'll be around 950 I think. But in gear between 450-550 is about where it should idle.
Old 08-12-2004, 01:20 AM
99SSinOC's Avatar
Temp was fine tonite... drove it around a bit, romped on it. Sounds soooooo damn loud, I'm almost afraid to drive it at night since I have no front plates, cops pull me over just for fun.
Old 08-12-2004, 01:49 AM
FatZ28's Avatar
The only way I could see headers making the temp raise is if the headers wernt coated or the headers actually made the car run lean and not rich, which I doubt.
Old 08-12-2004, 05:59 AM
Keenov's Avatar
I got a 6 speed. Idles 1k neutral, Headers brought it down to 900 or so.
