Highest RWHP #'s on cam only LS1???
Old 08-12-2004, 04:11 PM
Worm Boy's Avatar
Default Highest RWHP #'s on cam only LS1???
Just curious, whats the highest RWHP anyone has heard of with a cam only LS1? We just started to test our new cam and I want to see where we stand.
Old 08-12-2004, 04:31 PM
LSX Mechanic
Damian's Avatar
In the REAL world, highest i've seen was an FM10 cam, made 412 rwhp on stock LS1 heads....On the internet where people play all the BS tricks, who knows.....
You should clarify your definition of "cam only" because some people will try and compare their LS6 "cam only" which is not apples/apples...
Old 08-12-2004, 04:46 PM
The Juggernaut's Avatar
Mid 430's I would guess.Stock heads,stock bottom end.
As in just sliding a cam in a stock motor.
Old 08-12-2004, 04:50 PM
Yes, those are *internet number*
I think the highest independant numbers are 410ish.
I made 409/386 G5X2 (M6)
That seems to be high for Chicago numbers.FWIW
Old 08-12-2004, 04:52 PM
WAHUSKER's Avatar
I think I have one of the highest Hot Cam dyno queens - 391rwhp & 371rwtq SAE. Without locking the converter. Every car I've seen over 400rwhp had heads or a power adder.
Old 08-12-2004, 05:00 PM
Kurtomac's Avatar
Jason99TA of thunder put down 451rwhp with the TRex on stock 241 ls1 heads through stock rear, Smokin01TA also put down 420s through his 12 bolt and 456's with a TRex
I made 396 with stock pulley and stock Tbody with a XER 224 Comp cam
White Fire's Avatar
Didn't Jason99TA do 450 rwhp with a T-rex cam only?
Old 08-12-2004, 05:02 PM
ThackerSS's Avatar
Josh.. Distortion 69 that posts here, did 419, with a strange 12 bolt and 4.10 gears, with a custom FMS cam and all the bolt ons. Stock heads.
Old 08-12-2004, 05:22 PM
distortion_69's Avatar
As brandon said.. numbers in sig.. I'd like to think with 01-02 heads I'd have dynod a few more, but this ain't going to be no dyno queen anyways! I think the Futral cams tend to make a lil better torque than some competitors, dyno is in sig.. actually not all that huge of a cam (236/239 .601/.610 111lsa). I think t-rex has the highest dyno thus far, but that freakass car also dynod higher with an ls6 cam than most people dyno with some big lopey cams
Josh
Old 08-12-2004, 06:01 PM
MIGHTYMOUSE's Avatar
friend of mine in our car club
g5x3, stock rockers 02 firehawk m6, qtp longtubes, dual cutouts..electric waterpump, asp pulley 420rwhp. w/4.10 gears. done on an independent dynojet.
Old 08-12-2004, 06:03 PM
Unusual T/A's Avatar
Sig check
Old 08-12-2004, 06:25 PM
dame's Avatar
i did 399 with just the cam in the sig
Old 08-12-2004, 08:08 PM
ujslost2's Avatar
numbers in the sig, btw luv this cam.
Old 08-13-2004, 12:25 AM
JoeDirt's Avatar
Its no record but I managed 390/372 rwhp/rwtq through cats with a little 224 220 / 581 581 116 cam.
Old 08-13-2004, 06:59 AM
Black02SS's Avatar
Not the best, but my buddy just dyno'd his FM11 Cam and managed 401/395 on Speed Inc's. dyno.
Old 08-13-2004, 09:44 AM
Worm Boy's Avatar
Those are some impressive #'s. I will let yall know what are new HPE cam does probably later today.
Old 08-13-2004, 10:19 AM
CamaroCain's Avatar
Are you guys going to try and get a car setup for the cam only class at Thunder?
Old 08-13-2004, 10:38 AM
Z28 Z's Avatar
check sig....
w/ mac's ORY, borla, & underdrive pulley
Old 08-13-2004, 12:08 PM
Chuck@'s Avatar
No, just doing a little R&D. This is one of our first bolt in cams, and has a lot of p-v, and is making as good or better than most everything mentioned here. We will probably post up more information later today...
Chuck
Old 08-13-2004, 12:12 PM
Chuck@'s Avatar
Chuck
Oh, and I forgot to mention that our car is a 99 with a full exhaust. So this should be a pretty sick cam.
Chuck
Quick Reply: Highest RWHP #'s on cam only LS1???
