K-members, which is lighter?
Re: K-members, which is lighter?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by badass 2002 z28:
<strong>PA mild steel or BMR mild steel?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The BMR is lighter because of thier motor mounts.
Paul
<small>[ November 26, 2002, 08:54 AM: Message edited by: Paul @ Thunder ]</small>
Paul
mild steel BMR is 31 pounds lighter than stock kmember.
I'd be curious to see how much a cromoly PA k member would weigh when used with Madman motormounts. This might be even lighter.
How hard is a k member to put in? Time? Can it be done in my garage? Is a lift a must?
Sorry to Hijack the thread, but I think we got the BMR is lighter.
Thanks.
Thanks.
Hey guy`s just to let you know our chrome moly tube k-frame and a-arms weigh in at 27lbs!! which if I`am not wrong that`s about 40lbs dropped! if your interested check out our specials! https://ls1tech.com/ubb/ultimatebb.p...;f=10;t=001292 <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
2000SILVERTA, yes you can do it in the garage. Pull off the shocks/uprights or support them with jack stands. Support the engine with jack stands. Remove the 8 motor mount bolts, rack and pinion, brake lines, and 6 retaining bolts. Put new one in put everything back in. You will have to fabricate something to hold line to the k-member at least were it goes from tube to hose.
Gary
Gary
