Drag Racing Tech
Is there any way to remove welded-on SFCs?
Old 12-14-2002, 01:52 AM
quickWS6's Avatar
Default Is there any way to remove welded-on SFCs?
Is there any way to remove some boxed SFCs and re-weld a set of chrom moly tubular ones in their place? Will cutting off the old SFCs cause any problems? Has anybody done this? Thanks a lot!
Old 12-14-2002, 07:42 AM
2000SILVERTA's Avatar
Default Re: Is there any way to remove welded-on SFCs?
If all there are is a few stitch welds you should be able to just grind em with grinder until they pop(yes,most of them will POP). Please wear safety glasses and gloves with a long sleeve shirt if possible. OH yeah, a friend would help to keep the sfc from falling on your head.
<---SAC, hates it when things fall on his head. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old 12-15-2002, 03:02 AM
quickWS6's Avatar
Thanks man, I'll have to add that mod to my list now that I know it isn't a real big deal.
Old 12-15-2002, 05:07 AM
LSX Mechanic
Damian's Avatar
Take a ziz-wheel and go to work. It will take you a WHILE, but if the welds aren't to serious you should be able to get them off. I am going to tackle this task myself soon.....
Old 12-15-2002, 07:03 AM
Vic@FishersAutomotive's Avatar
Yes, I have personally done that before on a several of cars. It is a lot work. Take your time and be carefull around the fuel lines.
Vic
Old 12-16-2002, 01:45 PM
quickWS6's Avatar
Will do, thanks guys. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 12-16-2002, 06:06 PM
Jantzer98SS's Avatar
I torched mine off for the most part and grinded down the welds etc. remaining. I saved atleast 7lbs going to tubular chromoly from boxed.
Old 12-19-2002, 05:52 AM
smokinHawk's Avatar
were do you get chromoly SFC?
