Installing cam in 2000 Z-28
Old 03-28-2003, 10:28 AM
SDB
SDB's Avatar
Default Installing cam in 2000 Z-28
Need instruciton/advice on installing a cam in a 2000 Z-28 (auto, coupe). I will use the stock lifters, but will be replacing a B1 cam with a X1 cam (built motor my MTI). What tools and gaskets, fluids, etc will I need for the change? I assume I can do this by removing radiator and front "stuff" with motor in car. All input and insights from those that have done this would be appreciated.
Thanks
Old 03-28-2003, 10:35 AM
770Guy's Avatar
Default Re: Installing cam in 2000 Z-28
Do a search and you can find a complete cam swap guide, its perfect. Picture by picture details, I used it when I did my cam swap, took me about 5 hours to swap it out, without air tools, it was surprisingly easy. Ill look around for it if you dont find it.
Old 03-28-2003, 10:44 AM
98 LPE SS's Avatar
Here you go. This is the one I used when I did my cam swap.
http://ls1info.com/article.php?sid=4...rder=0&thold=0
Old 03-28-2003, 10:49 AM
MattB4C's Avatar
here is a good one:
http://www.ls1howto.com/index.php?article=2
Old 03-28-2003, 03:25 PM
SDB
SDB's Avatar
thanks for the info....ifI elect to have the cam installed for me, what would be a "normal" price for a cam swap, from a dealership?
