tsp true dual instalation question
Old 08-26-2004, 06:33 PM
LSONE's Avatar
Default tsp true dual instalation question
ok, everything is done, connected, and good, a little tough to fit them together, but after a little bit of a fight i got them on.
now, here's my question.
i used the clamps to temperarily hold everything till i can get it welded. after a drive around the block i noticed it was hanging like 2 inches off the ground at the back. i noticed those tabs have holes in them but couldnt find a bolt to attach them too. is there anything i can do to hold it up before i get it welded?
Old 08-26-2004, 06:52 PM
skippytheloon's Avatar
What the hell! Are you driving around without the bullets attached to the car(hangers)? I wouldn't do that, if that's what your talking about, I'd leave the mufflers in the trunk until you can weld the hangers...or you could drill a hole and put a bolt/nut through it.
Old 08-26-2004, 06:57 PM
LSONE's Avatar
yeah, just cuz i wanted to hear it
but i also thought about drilling a hole and putting a bolt through, do i have any other options?
Old 08-26-2004, 07:03 PM
tomaSS's Avatar
Yeah, I would not suggest driving around without the hangers attached. I'm with skippytheloon, drill a hole and stick a bolt through it until you get it welded.
Old 08-26-2004, 07:05 PM
Z28Venom's Avatar
HAHAHA...
Thought that I was the only impatient person around here. Yea man, you should disconnect the bullets until you can get a shop and have them welded. You'll shot yourself if they snag something and get ripped off.
LSONE's Avatar
i actually thought about that before i did it, but i'm not too keen on taking the seats out then drilling a hole through the back of my new car. but i guess ya gotta do what ya gotta do.
Old 08-26-2004, 07:06 PM
cyphur's Avatar
not really. just drill a hole and attach them that way. or like skippy said, run just the x-pipe til you get to your welder
LSONE's Avatar
but they sound so good
Old 08-26-2004, 07:09 PM
That's all I can think of, those bullets are pretty heavy and the only thing holding that entire exhaust up is your headers...I wouldn't think thats good. I don't even have to ask if you like the sound
BTW: I'd get some good band clamps to replace those U-bolts, say you go over some railroad tracks or hit anything not rounded off. If you scrape a band clamp it'll scratch the exhaust...but if you scrape a U-bolt, it might catch and the whole exhaust may rip off.
edit: don't worry about it, I didn't think the metal was "that" thin and burned through when welding them on. Carpet caught on FIRE! (well, it kinda smoldered ) Just watch under your rear seats when they are welding please.
Kyle
Old 08-27-2004, 09:48 AM
evergreen0077's Avatar
i was told by the exhaust shop i took my car to that they could not weld it together because it was aluminum?? is this true?
Old 08-27-2004, 01:16 PM
1BadMoFo's Avatar
I believe the system Aluminum coated steel, not aluminum.
Old 08-27-2004, 03:28 PM
Hawkcmc's Avatar
You took it to a shop that couldnt recognize Aluminized Steel? Time to run like heck to another shop.
CMC
Old 08-27-2004, 08:29 PM
Clipper's Avatar
CMC
It's almost hard to believe... run like Forest!
Old 08-28-2004, 03:14 PM
ZR2877's Avatar
I just got my TSP true duals that dump at the axle. Are these the ones you are talking about? So there is welding required. They are sitting here waiting for installation.
Old 08-28-2004, 05:07 PM
Krab's Avatar
When I was contemplating about buying this system (Actually, I still am), I knew I would rather drill a hole through the floorboard to hold up the back of the exhaust instead of welding it. This way I can always take it off whenever I wanted. Just my .02.
