Drag Racing Tech
Coach, Jason, Allan, Joe, Tony...
Old 02-09-2003, 07:38 PM
!Dial-up Director
Sears's Avatar
Default Coach, Jason, Allan, Joe, Tony...
and all 6 speed drag racers..
I am about to order 28" Mickey Thompson ET Drag slicks. What do you guys run, the regular sidewall or the stiff sidewall?
Thanks,
Justin
Old 02-09-2003, 07:48 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Default Re: Coach, Jason, Allan, Joe, Tony...
I think the tire you need is the 672-3055S 28x10x15 is for a stick Hot Rod. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
I run the 3066ST M/T slick now it is 30x9x15 made just for a stick Hot Rod. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Good luck to ya. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Coach
Old 02-09-2003, 09:59 PM
I can shift faster than you.
Jason99T/A's Avatar
Justin, I'm running the regular 3055 (non-stiff sidewall). I may try a 3055S once these wear out, but I'm not sure. I believe Allan runs the same tire I do, but Joe is running the S.
Jason
Old 02-09-2003, 10:05 PM
Futral's Avatar
Yep currently I have the regular side wall but my next set I am going to try the stiff sidewall.
Old 02-09-2003, 10:19 PM
Fly By's Avatar
What, if any, are the differences/launch characteristics, growth rate, stability, ect.. between the 2?
Old 02-10-2003, 12:31 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Hmmm, didn't know they made different ones. I bought mine slightly used from BeaSSt when he changed slick sizes for the Thunder Shootout.
I do know that there are tubes in mine. I had Hoosiers with their stiff sidewall and they hooked pretty damn good and felt really stable on the big end.
-Tony
Old 02-10-2003, 05:48 AM
!Dial-up Director
Sears's Avatar
Thanks guys, I will give the 'S' a try.
Justin
Old 02-10-2003, 01:22 PM
CHRISPY's Avatar
These available in 26 inch size?
thanks,
Chris
Old 02-10-2003, 08:00 PM
JS12's Avatar
i also want to know that Chris. how much more stiff are these and how do you people hook on them if the softer sidewall helps on the launch? i have the regular ET drags and they feel pretty crappy going through the traps
Old 02-11-2003, 12:04 AM
Jason99T/A's Avatar
Justin, M/T recommends the "S" tire for those with a raceweight over 3000lbs and in a high horsepower application.
Jason
Old 02-11-2003, 12:26 AM
!Dial-up Director
Sears's Avatar
You are all are cuttin damn good 60's, but Joe and Tony have heavier cars. Does sidewall stiffness relate to vehicle weight? Would a heavier car prefer a stiff sidewall tire and a light car run a regular wall? What I am trying to get at here is the theory behind sidewall stiffness?
Justin
