descreen with FIPK or not
Old 08-29-2004, 10:17 PM
7 Second Club
ty_ty13's Avatar
Question descreen with FIPK or not
I've been reading alot lately about descreening the MAF and wondered if having a fipk and a descreened MAF on a '02 Z28 would make a difference or not...would it be a good idea to descreen or leave it
Old 08-29-2004, 10:45 PM
Spdmini's Avatar
I say leave it. You never know when something freaky may happen then you would have a bunch of **** in your TB and intake, to me personally its not worth the risk
Old 08-29-2004, 11:09 PM
ddelallata's Avatar
I have a FIPK with a descreened MAF sensor; no problems here. Mine is a 99 with an M6. I wouldn't descreen if you have an automatic.
Old 08-29-2004, 11:13 PM
2_wacko's Avatar
I think to be on the safe side leave it alone but what ddelallata said is true. You might get a damn SES light .
Old 08-30-2004, 07:01 PM
7 Second Club
ty_ty13's Avatar
Default bigger maf?
If i dont descreen it...would a larger(granatelli) MAF give me more hp...or what about the ported maf meter housings by thunder racing?
Old 08-30-2004, 08:04 PM
ddelallata's Avatar
You don't need to upgrade. I think that the stocker even with the screen on is good for a little over 600hp. If you are careful you can remove the screen in such a way that you can always just put it back on if you start having driveability issues. Just my .02
Old 08-30-2004, 09:39 PM
cyphur's Avatar
yea, you're apparently stuck on this maf issue. the ONLY reason you want to mess with the maf is if you can TUNE the differences. the maf is a VERY sensitive peice of equipment.....leave it be. even cleaning it harshly is a bad idea. porting the stocker, or getting ported ends, alters the air flow...which ***** up the pcm's computations(which is why it must be tuned for). all around bad ****** idea.
also....if you port and polish the stock heads...then, by all rights...they wouldn't be stock heads any more, would they??
Old 08-31-2004, 12:34 PM
STF Veteran
TA TED's Avatar
What he said ^^^^^. Don't **** with it man.
Old 09-01-2004, 08:25 PM
7 Second Club
ty_ty13's Avatar
Thumbs up ok you convinced me
ok im convinced
