Do you screw your ET Streets
to the rim <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> LMAO
I didnt screw mine down but some guy at the tire shop swears I need to.
Im really not plannin on going below 16PSI in them
26x10.5x15 on a 15x8 rim
Re: Do you screw your ET Streets
No, and few do. I used to run mine at 11 psi with no problems. When new they would slip just a little the first couple of passes and then they would stay put.
In 19 years of drag racing i have never screwed the tires and have never had a problem.When i mount the tires i put a little dish soap on the bead and when it drys it is like glue.Good luck and hope this helps. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Anyone who has mounted a set of ET Streets can tell you that they do not go on the rims easily. It's doubtful they would ever move much on the rim.
I have screws in mine.. Drilled the rims before I mounted the tires.. so I had to fill the holes <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
You wouldn't beleive my reaction when I saw this thread.
Well I don't want to get off topic so....... I haven't seen anyone put screws in E.T. streets before..........
Josh S.
Josh S.
hd, you aint making enough power to spin the tire on the rim..... <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by EVIL:
<strong> hd, you aint making enough power to spin the tire on the rim..... <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">just make sure you bottle is full May 3rd focker <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> if not u better say a prayer <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> LMAO
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
Screwed my et streets,didnt at first tire would spin about 2 inches on rim with 6000rpm clutch dump sticky track(560rwhp)4.10s.Probably more dependent on hp level and track conditions.Most fast cars(10,9,8 sec)around here are screwed.
