Power to the PCM?
Old 09-04-2004, 05:30 PM
libertine1015's Avatar
Default Power to the PCM?
Does anyone know which wire brings power to the PCM? I am using a battery disconnect as an anti theft measure and when I turn the battery back on in the morning the PCM has to keep re learning how to idle my nasty aftermarket cam and its a pain in the a$$. At least I think this is whats happening so I want to run the PCM power wire to the hot side of my battery disconnect so it always has power. Any suggestions or info is much appreciated.
Thanks!
Old 09-04-2004, 10:21 PM
horist's Avatar
you'd be better off just wiring in a toggle switch to turn the fuel pump relay on /off ... maybe a toggle switch inside the glove box or something...
That way you have your stock (or aftermarket) alarm system armed , car doesn't have to relearn idle, and it's a theft deterrant as well...
Old 09-05-2004, 01:16 AM
chpmnsws6's Avatar
what about if you have a safety shut-off switch?
i need to find out the same thing
Old 09-05-2004, 10:17 AM
Does anybody have a wiring diagram with the PCM mapped in it??
Old 09-06-2004, 02:34 PM
P Mack's Avatar
Looks like pin 20 on the blue connector should go to the battery. It's an orange wire close the the middle of the connector.
Old 09-07-2004, 07:45 AM
gameover's Avatar
99-04 V8
1: GND
19: IGN (+12V)
20: +12V
40: GND
57: +12V
58: VPW serial
Blue connector.
Old 09-07-2004, 03:11 PM
Sorry, I have a 98. Do you guys have that one handy? Anyway you could email me an Adobe?
Thanks guys, much appreciated!!
libertine1015@hotmail.com
Old 09-07-2004, 03:24 PM
gameover's Avatar
98 V8
19: IGN (+12V)
20: +12V
21: GND
58: VPW serial
60: GND
Blue Connector
Old 09-07-2004, 04:29 PM
Awesome, thanks so much. Did you read the whole post? does this make sense or am I always going to have an idle problem until the o2's heat up? should I have my VE tables edited?
