Afr Heads
Afr Heads
Well AFR Heads have been out for a while some of the BIG tuners have them.
How come no #s I here they are off on power. Can some of the tuners post here or pm me. Wanting to make a move don't know what head to go with.
SN95 Director
the heads have barely been out, only a few people are running the 205's and have posted numbers. those are more important then any shop numbers. Tony has already addressed the 205's and stated that over a properly ported 5.3/5.7 the gains will be minimal or on par. the 225's should be the big ticket numbers but they arent out yet. a few sponsors have gotten a hold of the bare castings (200's), i believe TEA got 346cfm out of them and had a FI guy pushing 1000rwhp with them.
This is B.S Cartek MTI ARE Whats going on no one has used AFR heads.
#s please. Why would i want to used them if they don't make more power then LS6 heads on a N/A set up.
I agree.
There was one shop that called them into question based on one poor dyno and Tony set the record strait on what the heads were - Then these heads came off the map for whatever reason.
Vendors are not posting numbers (even AFR) and you know they would. Not since those good numbers came up with shaved heads & notched pistons (and whatever else LGM did). I assumed LGM would champion these like their kick butt headers but that has not even come close to happening.
Maybe it is more profitable for vendors to continue porting stock castings to similar results.
ttt
This bears more watching and research..... I WANT THEM!!! I simply am not ready to throw down the $2300 + to be one of the first on the block....
Originally Posted by Mirek
I agree.
Originally Posted by SideStep
ttt
I have a set in hand I recieved yesterday. First impressions:
1: Very substantial. More meat everywhere, deck, waterjackets, walls, etc.
2: Very clean castings. No pinholes I could readily see.
3: Very nice porting job. They look like jewels.
4: Complete with Patriot Gold duals, titanium retainers, and seats.
5: I'm using Harland Sharp 1.7's and the heads will need the sidewalls clearanced due to interference.
6: I don't know what the valve cover clearance will be also. I have to pull mine check.
I had them shaved and will be using an .040" Cometic Gasket. Compression should be around 11:1. I'm using a Comp 224/228 .581/.588 112+2. One point of note. These heads really are LS1 Stage 1 and 2 upgrades, not LS6, hence the 205cc intake runner. They are geared more to the street and not race. The flow numbers bear this out. There was one tuner that ported these out further and got 346cfm (see jrp's response above). I wanted more of a street head than an all out race head or else I would've bought the 225's when they cam out and used a bigger cam. These heads with the associated proper cam are probably better suited to a stock bottom end. There was a 03 vette that ECS did with a set of these heads and a G5X3 that did 449rwhp. I don't know if they played games with cr/shaving or thinner gaskets. pdd did 435 with his setup. When the 225's come out I'll bet based on the 205's numbers there will be some very impressive gains to be had using these heads, especially with bigger cams, but I think you'd better have forged internals for the kind of power they are going to produce. I will post my results when the smoke clears in a few weeks. I need time in the shop and I've got to convert an automatic RX7 to a 5 speed this weekend.
How much exactly did you mill them to achieve 11:1 w/ the .040 cometics ?
When are you going to dyno.....???
