Survey: How much airflow at idle.
Old 09-10-2004, 04:58 PM
QuickSilver2002's Avatar
Default Survey: How much airflow at idle.
Just trying to collect some data from different cars.
How many g/sec of air do you move at idle.
Please specify. RPM, CI, CAM, and IAT.
Old 09-10-2004, 05:04 PM
LS1derfull's Avatar
7.5 g/sec @850 346" MMS 220*on a 112* 100*F
Old 09-10-2004, 05:09 PM
red ws6 99's Avatar
You should also be asking at what altitude (makes a huge difference) you are at and other relevent mods like turbos.
Gary
Old 09-10-2004, 11:32 PM
horist's Avatar
looks like it bounces around 9.20
382, 236/242 593/603 112 cam, 120s IAT
Old 09-11-2004, 05:17 PM
LS1derfull's Avatar
My bad i stated my idle gms/sec were 7.5 but i checked today and they were around 8.5 at same idle rpm.
Old 09-13-2004, 04:18 PM
Bink's Avatar
Gary
Altitude doesn't effect mass - that's a major advantage of using the MAF.
Common misconception.
joel
Old 09-13-2004, 05:32 PM
7 Second Club
NicD's Avatar
I would think that the mass of the air does change with altitude. The main benefit of the MAF is that it can read that change.
Old 09-13-2004, 06:06 PM
Bink's Avatar
Altitude effects density. Density = mass/volume. The higher the altitude the less mass per unit area. MAF outputs (theoretically) frequency = mass/sec.
So altitude does not change it - you'll need to flow a greater volume of air at higher altitude to get the same air mass into the engine. Make sense??
joel
Old 09-15-2004, 07:19 PM
red ws6 99's Avatar
joel
Think you missed the point. With less oxygen in the air you will have less mass flow into the engine for any given rpm when compared to sea level. I am only moving 4.5 g/s at 550 rpm, at sea level car would be moving ~6.5 g/s (what the air flow tables are programmed for). It makes the car sound like they have an nice cam in them at higher altitude, since they are barely running.
Gary
Old 09-15-2004, 07:44 PM
Bink's Avatar
Gary
Nope...that IS my point. I completely agree with you.
The beauty of the MAF is it is able to accurately report the mass of air and thus the PCM can accurately deliver the correct amount of fuel. The correct mass of air is reported regardless of density. MAFLESS ( Speed Density) - atmospheric pressures( Baro) has a huge effect on the tune due to fueling inaccuracies. Think about the density changes with elevation!! Nightmare.
I'm not trying to argue........just trying to stop the myth.
joel
Old 09-16-2004, 01:04 PM
marc_w's Avatar
You're talking metered, not "requested via the table", right?
7-8 in P/N.
7-7.5 in G.
Requested:
6.25 in P/N
6.50 in G
Old 09-16-2004, 07:00 PM
red ws6 99's Avatar
7-8 in P/N.
7-7.5 in G.
Requested:
6.25 in P/N
6.50 in G
I am talking what the maf is reporting without the air conditioner on. With air conditioner on the numbers jump up a bunch ~1.5 g/s
Gary
Old 09-16-2004, 08:14 PM
P Mack's Avatar
I have logs from San Antonio (800 ft, 100 kpa baro) and Colorado Springs (7000 ft, 80 kpa baro). Both are with a 222/222 112 lsa cam, 800 rpm idle, 5.7 liter.
San Antonio: 7.8 g/s
C Springs: 6.7 g/s
Oh yeah, and MAP at idle was ~50 kpa in San Antonio, ~40 kpa in the Springs.
Old 09-18-2004, 11:40 AM
7 Second Club
NicD's Avatar
C Springs: 6.7 g/s
Now that makes sense. The density of air will be different at elevation compared to sea level and the motor obviously doesn't change displacement so the mass air meter will read that difference.
Old 09-18-2004, 01:05 PM
Another_User's Avatar
The dynamic air on my MAFless setup says that it is getting about 10 g/sec at idle @900rpms.
Old 09-18-2004, 08:44 PM
deezel's Avatar
570 RPM, 364c.i. (6.0L), stock cam, IAT 91*F
MAF and PCM dynair both agree:
P/N = 7.3 g/s (MAP 38)
In gear = 7.8 g/s (MAP 42)
Old 09-18-2004, 11:01 PM
Your PCM dynamic air will read the same as your MAF. I am MAFless. Pull the plug on your MAF and watch that number change when you restart your car.
Old 09-23-2004, 09:16 PM
P Mack's Avatar
Found and old log file from when I was stock.
Same as my other post except no headers or cam.
Altitude: 7000 ft
Baro: 80 kpa
MAF: 4.9 g/s
MAP: 24 kpa
Quick Reply: Survey: How much airflow at idle.
