Timing Chain
Timing Chain
I have a ls1 engine but it had no timing chain and I'm wondering should I just use oem or go aftermarket; if aftermarket is the way what is a good name brand?
Thanks for any help
Thanks for any help
Go with a double roller, Rollmaster is a popular choice and available from SDPC
http://www.sdpc2000.com/cart.aspacti...2267&pid=90940
J-WIS will do, much easier to install, no need to remove crank sproket (unless damaged of course)
BTW I believe this is the chain they use on C5R "LE MANS" corvettes.
Originally Posted by Cstick
How much do you have to machine off your underdrive pully to use double rollers? Can a single roller Rollmaster be used without machining?
