can some one exlain this torsen zexal "rocks in a box" noise
Old 09-14-2004, 01:02 PM
pewterta's Avatar
Default can some one exlain this torsen zexal "rocks in a box" noise
for about 12k ive had this noise.. at low speeds under 20mph and on left hand turns only...the noise is there...
i need to drive 500 miles... this weekend...do u think it would be ok?? noise isnt gettin worse...its been constant same noise...
thanks!!!!
Old 09-15-2004, 02:27 AM
MyLS1Hauls's Avatar
Mines sounded like that for 50k miles. The gears are just a little loose in the carrier. Not a huge deal.
Old 09-15-2004, 02:41 AM
Jorday's Avatar
Yeah, mine's noisy, too. My old WS6 also had the noise. Like he said, nothing to get too worried about.
Old 09-15-2004, 04:32 PM
pewterta's Avatar
really?! my 1995 ta never did it..but i guess that had a auburn in it....
hmmm...
speeds over 20 no noise...right hand turns no noise... highway no noise...i jus dont get why under 20mph and left hand turns only i have this noise.... so irratating!
has anyone ever gotten this noise to go away?
Old 09-15-2004, 04:36 PM
2xLS1's Avatar
Although it's not supposed to be required on Z/T carriers, the GM Posi Trac additive is supposed to help quiet them.
Old 09-15-2004, 06:36 PM
pewterta's Avatar
did that...matter of fact..i put 2 bottles of the additive in...
anyone else?
Old 09-16-2004, 06:07 PM
XFiveLiter's Avatar
Can you describe the noise in more detail? I have been getting a clunking noise only on left turns. I was getting a little wheel hop at the track last week and after that it started.
I have the rear cover off now and can't see anything obviously broke. The gears inside the carrier SEEM to be OK.
Old 09-16-2004, 07:43 PM
GuitsBoy's Avatar
I just swapped some 4.10s in and now Im getting the Left hand turn whine. The differential was always silent before the gear swap. Im still breaking in the gears with a non synthetic gear oil. Once I put mobil1 and the LSD additive back in, ill worry if the noise is still there. I also have just the slightest hum @ 55 with these gears, but i never notice it unless in trying to listen for it.
Old 09-18-2004, 07:34 PM
pewterta's Avatar
i would say it sounds like a loud clicking noise... and then when i straight out(at low speeds..) it still makes the noise.... jus got back from michigan..and reareend didnt break or anything....500 miles..of driving... i jus dont get it..i mean if it were going to break it would of broke by now right? were talking 13k withthe noise now??"?
Old 09-19-2004, 11:26 AM
Mike94ZLT1's Avatar
Wierd.... I get a strange clunk when I make right hand turns, but left hand turns seem to be ok?!?
Old 09-20-2004, 01:11 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I have that EXACT same noise, and have had it for about 20K miles on my current stock rear end. I've never run drag radials, but I do have a RAM Powergrip HD clutch that grabs pretty hard, and I haven't broken anything yet, and this is with some pretty hefty 6K RPM downshifting to second dumps. The noise isn't getting any better, but it really isn't getting any worse either.
Personally, I think it is on borrowed time, and have plans of a 12 bolt after the first of the year. There are a lot of people that have this type of noise, but it never really bothers anything unless you run a sticky tire.
Take this for what it's worth...
Steve
Old 09-20-2004, 02:59 PM
pewterta's Avatar
i do have an extended car warranty... but my mechnec says i should wait till i blow up the rearend first... i he thinks they will send an adjuster out to look at the parts....if they find a damagged part..im clear..but if they dont...im left paying for the teardown of the rearend...
any thoughts or opinions???
thanksa lot guys!
Quick Reply: can some one exlain this torsen zexal "rocks in a box" noise
