has anyone narrowed a rearend 2"
Originally Posted by BTL FED
I have narrowed 3" per side, and I am going to run 15x10 with a 5" BS, it should sit the rims 1/2" in, more than stock
Who did your setup for you? Did you mini tub?
mines been narrowed 2" per side, however it has not been installed yet. i have done a search in wheels and tires with a key word of "slick" or something like that, tried a few. anyway, there is a guy with that same setup, 15x10 w/5.5" b.s. and it looks ****!!! can't wait to do mine. btw.....15x10.5 hoosiers. it's a red ss and the link/pics will be on car domain.
later,
Dave
later,
Dave
Originally Posted by cam
Why would anyone want yo narrow a rear two inches whe you can just buy a third gen rear that is already two inches narrower? Same bractets etc just 2" narrower.
i looked into it
89 and newer disc brake rears. Same flange... in fact same PBR brakes as 93-97 rears. 88 and older version did use a different brake set up and the flange is different. One even better for you if you can find a 9 bolt Austrailian rear they are stronger than the 10 bolt and use bolt in axles.
Originally Posted by 1fastWS6
Squintzpallatore narrowed his. He has some pics up. It looks sweet. Search his username.
Your talking about this?
https://ls1tech.com/forums/wheels-tires/203384-pics-my-convo-n-hoosier-combo.html
